I'm new as of yesterday and I'm sure you all know the answers to my questions. What is the best strut tower brace and exhaust for the base vibe. Also on the CAIs do they have all the factory electronic hook ups? (sensors).Thanks!
welcome to genvibe! let me direct you to the wonderful feature known as SEARCH. there are SEVERAL (and i mean many) threads addressing all of those items you are asking about. i'd recommend searching the site for info or even just looking in the appropriate forums. with most newbies, they tend to ask the same questions... especially regarding those 3 things. welcome and i hope you will find all the info you are looking for!
Most strut tower braces are the same and are mostly for looks on the Vibe. The fire wall (the metal wall seperating the cabin from the engine compartment) is so close to the strut towers that it acts as a strut bar itself. So any strut bar you think looks good will work (as long as it's not over priced for what it does).In terms of exhaust this just depends what you want and how much you are willing to spend. If you want a the cheapest and and best for direct installation without additional modification of the exhaust then get the Magnaflow exhaust. If you want to spend a bit more for larger exhaust piping go with the Borla or GReddy.CAI's don't really have anything electronic on the tube itself but there is a crucial electrical component (the Mass Air Flow sensor or MAF) that you screw onto a prefabricated slot for it. Other than that all you need to do is attach the correct vacuum tubes and attach the intake to the throttle body (intake part of the engine) and put on the filter and bolt it to the chassis in one spot.Just in case you don't want to read throught the huge multitude of posts on all that (Mine's more condensed )
Quote, originally posted by Smokin' Rubber » In terms of exhaust this just depends what you want and how much you are willing to spend. If you want a the cheapest and and best for direct installation without additional modification of the exhaust then get the Magnaflow exhaust. If you want to spend a bit more for larger exhaust piping go with the Borla or GReddy.Actually the only difference is that Borla exhaust bolts right on and the Magnaflow you have to cut the exhaust pipe to install. Also their is more gains in HP on the Magnaflow. The sound is about the same.
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
Quote, originally posted by pntiac2 »Are there any modifications needed to install the TRD products on the pontiac?Welcome to GenVibe! I don't have any TRD products, but from what I understand the answer is no. The hook right up to the Pontiac just like the Toyota.
***SOLD***2003 Vibe GT Monotone Neptune - Inaugural October 2004 Vibe of the Month***SOLD***
Now the proud owner of Titanium Silver 2012 Kia Optima SX
Quote, originally posted by pntiac2 »Are there any modifications needed to install the TRD products on the pontiac?no. HOWEVER, TRD exterior parts like the grill or any other exterior part (bodykits, spoilers, etc) will NOT fit on the vibe. only the engine and interior parts.
Quote, originally posted by wicked1981 »Actually the only difference is that Borla exhaust bolts right on and the Magnaflow you have to cut the exhaust pipe to install. Also their is more gains in HP on the Magnaflow. The sound is about the same.Well yeah by additional modification I meant that you don't need anything that isn't in the kit besides maybe a good recipricating saw
