hope and pray everyoneim ripping apart the center console later today (havc and radio area) someone posted it might be behind there (matrixowners.c0m)lol my poor car is all scratched up from prying
Just found this which has a lot of the diagrams for this install when you click "read more":http://www.justanswer.com/ques...ng-toLooks really similar to what was done here.
Congrats SpeedEng!As for me, I'm just going to go with a universal kit thing and put a rocker switch next to the VSC button.
SpeedEng -- glad to see you made the trip at last! Things are looking bright for your VibeSo let me get this straight as your posts are all over the board. You got a generic OEM stalk with fog switch from a 2008 Toyota, the correct Denso relay, and a set of 2008 Toyota lights (not Vibe or Matrix -- same as the Corolla ones?); pulled the stock covers and installed/hooked up the lights; and they worked. You still have airspace around the outside of your lamps but you are working on that (or have it worked out) and are going to mod some kind of fascia.Question: did the lamp you used mount into the opening like it was designed for it or did you have to mod/build a bracket?Did you get photos of the lamp you were using before you mounted them in?A significant accomplishment. With this experience you may have a bright future as a car thief ahead of you !!
Gamma Vibe ==> 2007 Base 5-speed, Neptune
Delta Vibe ==> 2009 Base 2.4L 5-speed, Red Hot Metallic
but still more bikes than Vibes....
The dealer gave me a decent deal on parts and labor when I asked, so I had them install the factory foglights themselves while I was in for my recall stuff... I figure this way if something gets messed up, it's totally their fault. Everything works perfectly, it's a lot easier to see at night (though I still want to adjust my headlights in some way), and it looks great! I have a couple pics at night when I picked up the car, but the flash doesn't do much at night. I'll have to take some more in the daytime for the full effect.
No, it's there, the pictures at night don't do it justice. I will post some daytime pics tomorrow. ...though you made me paranoid enough to run downstairs and check, lol!
As for the moisture...hmmm... it had just gotten washed, and just driven outside from inside the warmer work area, that would explain why it fogged. Is this problematic?
Quote, originally posted by ponta2147 »No, it's there, the pictures at night don't do it justice. I will post some daytime pics tomorrow. ...though you made me paranoid enough to run downstairs and check, lol!Must be the lighting, it almost looks like it is not there. I do apologize.
No, I completely agree that you totally can't tell from the picture. I stared at it for a while and started doubting it myself! Like I said, daytime photos tomorrow (if I get the chance).
Ponta, they look fine even (especially) in the dark. I couldn't get either of the two local pontiac dealers to do anything except claim there was no kit yet and it therefore probably can't be done. The Vibe has always been kind of a stepchild there. So I bought the bezels and am waiting to see if a fix can be done. Sounds like Speedeng is close although I am not exactly sure what light he put in. Not the OEM unit for sure. May send him a PM
Quote, originally posted by bikeman1 »Ponta, they look fine even (especially) in the dark. I couldn't get either of the two local pontiac dealers to do anything except claim there was no kit yet and it therefore probably can't be done. The Vibe has always been kind of a stepchild there. So I bought the bezels and am waiting to see if a fix can be done. Sounds like Speedeng is close although I am not exactly sure what light he put in. Not the OEM unit for sure. May send him a PMThe only reason they did it for me is because I walked in there with a list of the part numbers and photos of what the parts looked like, courtesy of GenVibe! Between this and getting the splash guards, the people there know me now as "the girl with the part numbers" lol! But they did a good job with the install.
Would there be any interest in me, at some point, popping off one of the covers and getting some pictures of what the factory lights looked like in terms of shape? I know we all weren't sure of whether they were round or not... to me it seems like they might be.
You can do it for less than $100RH Foglight Ebay item number 1704707009998 $11.00http://cgi.ebay.com/ebaymotors...AX:ITLH Foglight Ebay item number 170470708696 $11.00http://cgi.ebay.com/ebaymotors...AX:ITCombined shipping $21.00 for a Ebay total of $43.00Buy the covers at the dealer GM part # 88975659 left outer cover list price $26.22GM part#88975660 right outer cover list price $26.22 GM dealer total $52.44 plus local tax Ebay $43.00 + GM parts $52.44 For grand total of $95.44You will have to do a relay and a switch that will cost you extraYou could also buy Ebay item 120544904862 acomplete set with wiring and relar and switch for $69.98http://cgi.ebay.com/ebaymotors...AX:ITThrow away the Camry covers and buy the GM covers above for $52.44 For a grand total of $122.42Check it out the actual lights are the same for the 07 –08 Camry as for the 09-10 Vibe
Dang, wish I had read the post about Bling lights earlier as well.I got the box in the mail, and it's just the lights, and wires no plastic molding or "fascia" so, there goes $90; plus the shipping I will have to pay to return them. ARG!Sounds like I will have to return them and start over. Ponta2147: What part # did you take in for the "blinker" mounted fog light switch? (i.e. able to turn them on by the headlight switch on the stick? Did they give you any issues on warranty or anything like that? Car looks great, I love yours! I have the same color!One last question, what does the "relay" do in this setup? Should'nt foglights work fine if they are directly connected to the battery with an appropriate 12V switch and fuse? What purpose is the relay?
Quote, originally posted by rvidolof »Dang, wish I had read the post about Bling lights earlier as well.I got the box in the mail, and it's just the lights, and wires no plastic molding or "fascia" so, there goes $90; plus the shipping I will have to pay to return them. ARG!Sounds like I will have to return them and start over. Ponta2147: What part # did you take in for the "blinker" mounted fog light switch? (i.e. able to turn them on by the headlight switch on the stick? Did they give you any issues on warranty or anything like that? Car looks great, I love yours! I have the same color!One last question, what does the "relay" do in this setup? Should'nt foglights work fine if they are directly connected to the battery with an appropriate 12V switch and fuse? What purpose is the relay?I actually didn't have the part number for the new stick switch, I just told them they had to order the one that turned on the fogs and it worked out, I guess they found it. No factory warranty issues since it's all OEM stuff... the car technically *could* have come with the same foglights installed, after all.
SpeedENG.do you need to buy 2 extra wire harness or it comes with the fog light you got it from a Highlander?I was afraid the wire bundle behind the bumper is too short for it to extend all the way to the bulb socket.
Ok , I got mine done...The unit I got off E-bay worked very well, it fits nice and looks original...Looks just as good as pretty Ponta,s ...Only the switch did not fit in the spot ,so I am going to get one witch fit perfectly...
Hi,I got the housing or insert from GM,and the lights, wiring,and switch from E-bay...The switch do not fit the Vibe , because the kit is for 2006-2009 Camry...
Thanks CQ358,Oh , and I got the power to the switch from the orange marker or signal lights wiring so I can turn it on or off anytime and it shuts off when I take the key out...So, I can have the fogs on with or with out the low beam ,or with the high beam...
SpeedEng,Great work! I have a 2010 and I'm just getting around to this mod now. I have all the parts, except for the relay, installed like OEM (The airbags and sterring wheel puller were a lot of fun when installing the new switch!). The only question I have regards the actual OEM Lamp assembly mounting. How many screws did you use and was there any special mounting hardware?I installed mine with just one screw, from behind through the alignment tab (located in the upper right corner (from the drivers perspective) of the passenger side fog lamp). The other side of the lamp assembly flanges fit nicely into the bumper cover and I didn't put any screw in those 2 spots or the bottom lamp assembly tab on the other side. It seems well secured with the one screw but I'm a bit concerned that I went a bit light on the screws.Your thoughts?Thx,Jay
I installed the ebay Camry foglightslights. They fit but not exactly the same as the oem ones do. I doubt anyone would notice though. I tested them yet but they connect to the factory harness. I also bought a used relay for about $5 on ebay. I think my local Toyota dealer wanted around $75. It is too cold now so I'll probably finish the install in the spring.
