Thanks! So I'm assuming don't change the filter again? Just do a drain from the plug or do a pan drop? Put like 1,000 miles on it between changes?
As far as I can tell, the solenoid is inside
. I may pop the electrical connector and spray some electrical cleaner on it.
zbyers wrote: ↑Wed Sep 25, 2019 3:32 am
You may need to change the fluid a few times to get all of the old fluid out. IIRC, a drain and fill only removes about 20-25% of the old fluid. Theoretically, if you do 4-5 drain and fills over the course of a few weeks/months, it would cycle out all of the old fluid. Doing that has resolved the P0741 for most.
