Hydraulic Jack Question
Posted: Mon Sep 13, 2004 11:39 pm
by StampedeVibe
This is probably a stupid question, but Canadian Tire is selling a 2-ton jack for $35. That should be more than enough for a Vibe, right?I figured I might as well check before I drop the Vibe on myself!
Re: Hydraulic Jack Question (StampedeVibe)
Posted: Mon Sep 13, 2004 11:58 pm
by nismo
yeah. 1 ton = like 2000 pounds, so, 2 tons should be good to go. But i would also recommend getting some jack stands.inder
Re: Hydraulic Jack Question (Salsa!)
Posted: Tue Sep 14, 2004 5:52 am
by satur9
i bought a jack that came with jackstands.actually a bought 2.and what i found out i really need is a good set of ramps.the vibe is less than 3000 pounds. but as long as you lift one corner at a time(instead of entire front or back)you should be fine.and before you laugh ive seen guys do this.
Posted: Tue Aug 30, 2005 8:33 am
by zionzr2
most of the time your jack is only lifting 1/4 to 1/2 the vehicles weight at a time
