Popping noise in 03' AWD Vibe...
Posted: Mon Sep 06, 2004 5:41 am
by pinkertonfloyd
Anyone else notice this, when taking off from dead stop, about 50% of the time I hear a "pop" from what seems like just behind the drivers seat...Ideas?
Re: Popping noise in 03' AWD Vibe... (pinkertonfloyd)
Posted: Fri Sep 17, 2004 12:33 pm
I haven't heard anything like that in my base 5 speed, and can't imagine what it might be. I have heard various sounds in this car, and I have a really hard time figuring out what direction the sound is really coming from. Helps to have someone else in the car who can move around to really pin down the location. Not saying the sound isn't where you said, just that I have been wrong a couple of times in this car.
Re: Popping noise in 03' AWD Vibe... (joatmon)
Posted: Sat Sep 18, 2004 5:33 am
by SCTM
Never heard that on mine either Pinker.. Is this coming from the inside or outside (behind the driver's seat)Inside: could be something loose under rear seat on in trunk. Make sure your rear cargo flat panel is "lock"... but look if your mother-in-law is not sleeping in before. Outside: check for loose hubcap plastic retaining bolts or wheel bolts, may be rear brake needs adjustment or your AWD system.By the way, welcome to Genvibe on your first post. Let us know when you find something.
Re: Popping noise in 03' AWD Vibe... (SCTM)
Posted: Sun Sep 19, 2004 3:49 am
by SCTM
Check on "Handling, Suspension & Brakes, Subject: Encountering any brake-related noises?may be related...
Posted: Sun Sep 19, 2004 4:13 am
by ragingfish
Sounds like their might be a loose bolt somewhere...If a bolt is loose, as you take off, the initial jerk from the take off could cause whatever that bolt is holding down to jump, causing the popping noise.
