Rear door pannel installation?
Posted: Tue Aug 31, 2004 5:35 am
by JVonD
Could you please tell me and others how to remove the window cranks on the vibes rear doors. Thanks!IM me at Yahoo please: jvond_tspThanks ~Jeff
Posted: Tue Aug 31, 2004 5:56 am
by Jahntassa
Either a window crank removal tool, a flat headed screwdriver, pick, or small needle-nose pliers.. (If it doesn't just screw off, I have the power package, so i'm not sure. There's a little spring clip holding it on. Carefully push back on the door panel to reveal the space between the panel and the crank, pull, or push the spring off, and the crank will just come off.-IF- that's now they did it. On some fords you have to pull up on the crank, which has a cover over a T-20 type screw.
Re: (Jahntassa)
Posted: Tue Aug 31, 2004 6:08 am
by JVonD
Yeah its un-powered. Thanks a lot!
Re: (JVonD)
Posted: Tue Aug 31, 2004 7:17 am
by ebslopp
Push the door panel in as far as you can around the crank, and take a look behind the crank arm. You will see a C shaped clip known as a "Jesus Clip" because when you take it off, you will say "Jesus!" and it will go flying. Anyways, you remove the clip and pull the handle off.
Re: (ebslopp)
Posted: Tue Aug 31, 2004 12:19 pm
by agbhyde
LOL!!!!btw, nice rims OP!!! THey look just like mine!!!
Re: (agbhyde)
Posted: Tue Aug 31, 2004 7:11 pm
by scherry2
this is the real tool to remove the clip but a small pocket screwdriver will work.
Re: (scherry2)
Posted: Tue Aug 31, 2004 11:50 pm
I've used a cloth, just pull it in between the door and handle. the cloth catches on one of the ends of the clip an pops it off the handle.
Re: (joatmon)
Posted: Wed Sep 01, 2004 5:41 am
by scherry2
Quote, originally posted by joatmon »I've used a cloth, just pull it in between the door and handle. the cloth catches on one of the ends of the clip an pops it off the handle. never thought of that. that is a good idea, and you don't go "jesus"
