Musky smell when A/C is on
Posted: Sun Jun 20, 2004 3:39 am
by makr0jeff
I turned my air conditioner on a few days ago and the a cabln filled with a wet mildew'y smell. Anyone know what would cause this? I was thinking cabin filter, how often should I change it.thanks guys
Re: Musky smell when A/C is on (makr0jeff)
Posted: Sun Jun 20, 2004 7:10 am
by JohnC
To prevent this in the future, just run the fan on high in the vent mode (a/c off, recirc off) for several minutes before shutting the car off. This will dry out the a/c evaporator condensation that causes the odor. This is a very common problem on all vehicles, although some drain better than others.
Re: Musky smell when A/C is on (JohnC)
Posted: Wed Jun 23, 2004 11:27 am
by ColonelPanic
Quote, originally posted by JohnC »To prevent this in the future, just run the fan on high in the vent mode (a/c off, recirc off) for several minutes before shutting the car off. This will dry out the a/c evaporator condensation that causes the odor. This is a very common problem on all vehicles, although some drain better than others.I'll second that. When I'm close to my destination, I'll usually kick off the A/C, crank up the fan, and make sure that the fresh air mode is selected. Otherwise, the water is sitting there in the system, stagnant. That stinks. Also, I've found in the past, if you run in recirculate mode too often, it could cause a bit of a stink as well.
