Seatbelt Lights
Posted: Thu May 30, 2002 8:58 pm
by Aquasax
Does anyone know how to disable the passenger side Seat Belt flashing light that comes on. It's annoying if there is weight on the seat that isn't actually a person. I don't want to accidentally disconnect the AirBag too. Any suggestions? Thanks...I like
Re: Seatbelt Lights (Aquasax)
Posted: Thu May 30, 2002 10:03 pm
by dlmetzger
You might just want to buckle the seatbelt instead of disconnecting things, IMHO.Dan
Re: Seatbelt Lights (dlmetzger)
Posted: Fri May 31, 2002 12:47 am
by d_m_kolb
I was just thinking the samething as dlmetzger. I wouldn't disconnect anything. You could do more harm than good. Just leave the seat belt clicked on the passanger side. When someone rides with you hopefully they will have enough sense to undo it and use it.
Re: Seatbelt Lights (d_m_kolb)
Posted: Fri May 31, 2002 1:53 am
by Aquasax
I guess that's an easy solution. It's just a pain in the (removed) to do that all the time - click it and unclick it. I'm lazy. I just figured someone else may have played around with it already and found a solution.
Posted: Fri May 31, 2002 2:13 am
by MA-VIBE-FAN
My thought would be to take a piece of black electrical tape, trim to cover light, and put in over it.
Posted: Fri May 31, 2002 3:29 am
by d_m_kolb
No one ever said you had to un click it everytime. The only time it would be unclicked is if someone was going to ride with you. When you get to where you are going and remove the weight leave it together. So allway leave it clicked even when you get out of the car.
Posted: Sat Jun 01, 2002 1:15 am
by Frosty
A Ralph Nader safety type would advise that anything heavy enough that will cause the car to sense a weight heavy enough to require a seatbelt, should be stored in the trunk.That would solve the problem. Sorry for being such an old fuddy duddy. cheers! Ken.
Re: Seatbelt Lights (kshields)
Posted: Sat Jun 01, 2002 9:44 am
by wrench79
i also hate that damn light. i was looking under the passenger seat and noticed two or three plugs. I'm gonna unplug one and see what happens. I'll let you guys know what comes of it.
Re: Seatbelt Lights (wrench79)
Posted: Sun Jun 02, 2002 2:38 am
by lopers
Why don't you just fold the front passenger seat forward and put your gear on the plastic cargo tray?
Posted: Tue Jul 09, 2002 3:33 am
by VibeInTx
Hey- It's aquasax! I know you
Re: Seatbelt Lights (VibeInTx)
Posted: Tue Jul 09, 2002 8:15 am
by lopers
Another solution for this problem is to buy an extra metal clip and just stick it in the holster unattached from the strap.
Re: Seatbelt Lights
Posted: Tue Jul 09, 2002 7:29 pm
by Aquasax
For the Record - I have no intention of messing with the 'safety devices' - it's a great feature in the driver's seat. Have you seen how sensitive the sensor can be in the passenger side? if you put a magazine on the sensor, it can start blinking - and MAN it get's annoying. When people ride with me - I make them wear their seatbelt (that is unless it's that time where we fit 10 people in the vibe and it just wasn't possible... ) The reason I haven't gone and disconnected anything is because I don't want to disconnect the airbag in the process. It's not a big deal...just a problem i figure other people have had, and I was hoping someone had found a safe solution... (man I sound like a little (removed)...sorry bout that)In other news - has anyone tried the "wet-wax as you dry" stuff? I used zip-it wash last week which has wax in it and it works ok. But man do a lot of bugs lose thier life below the grill!
Posted: Thu Jul 11, 2002 10:52 am
by NovaResource
A more simple solution would be to simply remove the light bulb behind the panel.
Posted: Thu Jul 11, 2002 9:05 pm
by d_m_kolb
Just all ways keep the passanger side seat belt fasten. Then weight or no weight it wont go off.
Posted: Tue Aug 06, 2002 7:35 am
by Greg100575
sorry for the late reply to this threadi was in the middle of replacing my factory radio, and noticed the passenger seatbelt light plug. its simply a 2 wire plug, i left mine unplugged and all is wellits been unplugged for about 2 weeks now with no troubles Greg
Re: Seatbelt Lights (Frosty)
Posted: Sun Oct 02, 2005 10:21 am
by tahoan
If you drove a vibe, you would know there is no trunk. A jug of milk or a laptop should not set off the sensor according to the owners manual. That is probably the source of the complaint.
Re: Seatbelt Lights (tahoan)
Posted: Sun Oct 02, 2005 10:33 am
by ColonelPanic
Wow, what a blast from the past. I don't even think any of the above members are still with us. lol!What year is yours, btw? I think I recall reading something in my '03s manual that mentioned the light will be triggered by items sitting in the seat. At any rate, the '03s light is quite sensitive, it takes little to set it off.
