Swapping out a NAV unit for another unit
Posted: Fri May 21, 2004 2:16 am
by jbernie1
Can you swap a NAV stock unit for in CD radio? I already have a CD changer.
Re: Swapping out a NAV unit for another unit (jbernie1)
Posted: Fri May 21, 2004 2:27 am
by ragingfish
You can swap out the Nav for an in-dash player (6 disc or single disc), but cannot reuse the changer. The other two head units have no way to interface with that changer.
Re: Swapping out a NAV unit for another unit (ragingfish)
Posted: Fri May 21, 2004 2:51 am
by esjones
What do you know about the changer? I see it is made by Pioneer. Do changers have a common method of connection to head units? If possible, I'd like to swap my CD changer out for a Mini-Disc changer.Thanks.
Posted: Fri May 21, 2004 12:55 pm
by Jahntassa
Nope. No can do. As far as I know, the only company that made MD changers is Sony, and you can only interface sony changers with sony HU. The fact that the Nav system has a Pioneer changer is a misnomer. The changer uses the GM 12pin interface, and not IP-Bus (the Pioneer standard). You might be able to change the changer for another GM 6-disc, but that's probably it. I don't think anyone makes a GM 12-pin interface to a Sony changer.Also, Mike is correct, neither the stock 1-disc or the in-dash 6-disc will work with the Nav changer.
Posted: Sun May 30, 2004 6:06 am
by blk182@n7
ill trade the my 6 disc for the nav unit
