Re: Master Parts Listing (ragingfish)
Posted: Thu Jun 17, 2004 1:20 pm
by ragingfish
Last Update: 11/08/04 ACCESSORIES AND ACCESSORY PACKAGES12498278, Active Package - FWD12498279, Active Package - AWD10952544, Battery Heater 80 Watt - 110V12495021, Bicycle Carrier Fork Mounted12498267, Bumper Protector12498133, Cargo Area Mat (Will not fit 2005 models with Monsoon subwoofer)17800790, Cargo Area Mat (2005 w/ M&T ONLY)12498132, Cargo Nets12498559, Cargo Organizer Multi-Purpose12370237, Distress Strobe Light12498310, Engine Block Heater12497926, Exhaust Tips - Bolt on RPA - Code NBG12498111, Floor Mats, Vinyl Rear Set, Base/GT12498155, Floor Mats, Vinyl Rear Set, AWD12498520, Floor Mats, Vinyl Front Set, All Models999681, Food & Bev AC Adaptor999679, Food & Beverage Warmer/Cooler *Discontinued*12498126, Front-End Cover w/o Logo (Includes hood cover)12498339, Graphics, Bodyside Silver (Requires two per vehicle) 12497328, Highway Emergency Kit12498125, Hood Cover Only w/o Logo12497374, Mobile Office Organizer12498661, Pet Safety Harness & Tether Kit Seat belt attachment (Small pet)12498662, Pet Safety Harness & Tether Kit Seat belt attachment (Medium pet)12498663, Pet Safety Harness & Tether Kit Seat belt attachment (Large pet)12498684, Roof Rack Utility Bars12498113, Seat Backpack Black12498134, Seat Covers, Water-Resistant Front and Rear Set12498152, Seat Covers, Water-Resistant Front Set12498153, Seat Covers, Water-Resistant Rear Set12498266, Seatback Storage w/ First Aid Kit12495610, Ski Carrier Roof Mounted, Holds 6 pairs of skis or 4 snowboards12497853, Ski Carrier Roof Mounted, Holds 4 pairs of skis or 2 snowboards12498056, Splash Guards, Molded Front Set - ALL YEARS MONO, 2003 2TONE ONLY IF NO RKR EXT12498057, Splash Guards, Molded Rear Set12498805, Spoiler Package Salsa12498807, Spoiler Package Abyss12498808, Spoiler Package Satellite12498809, Spoiler Package Primed12498773, Sport Package Salsa12498774, Sport Package Abyss12498775, Sport Package Satellite12498806, Sport Package Primed12498927, Supercharger - AT12499105, Supercharger - MT12378454, Vehicle Car Care Kit12498261, Vent Visors12495014, Visor CD/DVD Holder12499855, Splash Guards, Molded Front Set - 2003 2TONE W/ RKR EXT, 2004+ 2TONEPAINT, TOUCH UP12346659, Paint, NeptuneABS/BRAKES88969672, Sensor, Front ABS - RH88969673, Sensor, Front ABS - LH88970134, BPMV Unit, Base/GT88970135, BPMV Unit, AWD88971116, Bracket, BPMV88971202, Booster Assy, Brake88971203, Valve, Check88971205, Cylinder Assy, Brake Master, w/ ABS, MT88971207, Cylinder Assy, Brake Master, w/o ABS, MT88971206, Reservoir Assy, MT88971208, Cylinder Assy, Brake Master, w/ ABS, AT88971209, Reservoir Assy, AT88971210, Cylinder Assy, Brake Master, w/o ABS, AT88972183, Filter, Reservoir94851263, Grommet, Reservoir94853034, Cap, Reservoir94857030, Grommet, Check ValveAIR BAG SYSTEM88969204, Module, Driver Air Bag88969488, SDM Unit, w/o Side Air Bag88969490, SDM Unit, w/ Side Air Bag88969493, Sensor, Front End - RH88969494, Sensor, Front End - LH88969498, Sensor, Front Passenger88969652, Coil, SIR88970591, Module, Passenger Air Bag88970623, Back, Seat, w/ Side Air Bag, Light Gray, Passenger88970624, Back, Seat, w/ Side Air Bag, Dark Gray, Passenger88970625, Back, Seat, w/ Side Air Bag, Light Gray, Driver88970626, Back, Seat, w/ Side Air Bag, Dark Gray, Driver88972227, Module, Side Air BagAIR CLEANER17801-0D020, Air Filter, Engine 88969107, Element, Air FilterCARGO AREA88973453, Subwoofer Enclosure/Panel - 2005+CENTER CONSOLE88971514, Center Console Hidden Electrical Receptacle Cover88971515, Center Console Hidden Electrical ReceptacleCOOLING SYSTEMS88969094, Radiator Assy, Manual Transmission88969096, Radiator Assy, Automatic Transmission88969097, Cusion, Upper Radiator (R/L)88969098, Bracket, Upper Radiator (R/L)88969099, Hose, Upper Radiator88969100, Hose, Lower Radiator (Base, AWD)88969101, Hose, Lower Radiator (GT)88969161, Pipe Assy, Trans Cooler Inlet (Base)88969162, Hose, Trans Cooler Inlet (Base) (2) 88969162, Hose, Trans Cooler Outlet, Front (Base)88969163, Hose, Trans Cooler Outlet, Rear (Base)88969164, Pipe Assy, Trans Cooler Outlet (Base)88969165, Pipe, Trans Cooler88969166, Pipe Assy, Trans Cooler Inlet (AWD)88969167, Insulator, Pipe (AWD)88969168, Hose, Trans Cooler Inlet (AWD) (2)88969168, Hose, Trans Cooler Outlet (AWD) (2)88969169, Pipe Assy, Trans Cooler Outlet (AWD)88969174, Bracket, Clamp88969593, Pulley, Water Pump (GT)88969595, Gasket, Water Pump (GT)88969604, Housing, Thermostat (GT)88969605, Thermostat88970212, Tensioner, Drive Belt (GT)88970232, Belt, Drive (GT)88970731, Support, Upper Bracket (R/L)88971516, Fan, Cooling, Manual Transmission88971517, Motor, Fan, Manual Transmission88971518, Cap, Coolant Reservoir88971521, Fan, Cooling, Automatic Transmission88971522, Motor, Fan, Automatic Transmission88971576, Belt, Drive (Base/AWD)88972165, Pump Assy, Water (Base)88972166, Pump Assy, Water (GT)88972167, Pump Assy, Water (AWD)88972524, Shroud w/ Reservoir, Fan94853446, Clamp, Cooler Pipe94853450, Insulator, Pipe (Base)94853503, Cap, Radiator94856769, Gasket, Water Pump (Base/AWD)94856781, Gasket, Thermostat Housing94859856, Housing, Thermostat (Base/AWD)94860009, Tensioner, Drive Belt (Base/AWD)CRUISE CONTROL SYSTEM88969660, Servo, Cruise Control88969661, Cover, Servo88969662, Bracket, Servo88969666, Module, Cruise Control, Base88969667, Module, Cruise Control, AWD88969668, Module, Cruise Control, GT94857286, Switch, Cruise ReleaseELECTRICAL, HORN88970419, Horn94857229, Relay, Horn94857231, Stock Horn Mounting BoltELECTRICAL, IGNITION88970216, Ignition Coil, 2ZZ Engines88970217, Sensor, Crank Angle, 2ZZ Engines94859442, Ignition Coil, 1ZZ Engines94859444, Sensor, Crank Angle, 1ZZ EnginesELECTRICAL, MISCELLANEOUS88972396, Engine Fuse Block CoverELECTRICAL, STARTER88969483, Starter Assembly94854542, Relay, StarterENGINE/TRANS, 1ZZ88971575, Heat Shield, 1ZZ Engines94859510, Retainer Clips, Engine Heat ShieldENGINE/TRANS, 2ZZENTERTAINMENT SYSTEMS88973324, Subwoofer - 2005+EXHAUST, BASE, GT MODEL88969624, Manifold, Exhaust, GT88969126, Pipe & Converter, Exhaust, Base88969127, Pipe & Converter, Exhaust, GTEXHAUST, AWD MODEL88971578, Manifold, Exhaust, AWD88969129, Pipe & Converter, Exhaust, AWDFLOOR94858267, Carpet Retainer, Trans TunnelFRONT BUMPER88969810, Front License Plate Bracket88969813, Front End Impact Bar88969815, Emblem, Pontiac Crest88970433, Upper Front Bumper Cover Support, RH88970434, Upper Front Bumper Cover Support, LH88970437, Rubber Bumper Hood Stop88970439, Front End Impact Bar Bracket, RH88970440, Front End Impact Bar Bracket, LH88970441, Foam Impact Absorber88972146, Upper Front Bumper Cover88973186, Bumper Cover, Lower Front94858560, Retainer, Push In, Lower Front CoverFRONT DOOR, EXTERIOR TRIM88969791, Moulding, Front Door, Lower Side, RH88969792, Moulding, Front Door, Lower Side, LH88969817, Nameplate, "Vibe" (Adhesive)88969819, Nameplate, "Vibe GT" (Adhesive)88969940, Outside Power Mirror, RH88969941, Outside Power Mirror, LHFRONT DOOR, HARDWARE88969772, Weatherstrip Assembly, FRH88969773, Weatherstrip Assembly, FLHFRONT FENDER88969694, Fender - RH88969695, Fender - LH88969696, Fender Liner Assembly - RH88969697, Fender Liner Assembly - LH88969790, Retainer, Moulding - 10/Side88970762, Fender Liner Bracket - RH88970763, Fender Liner Bracket - LH88970767, Retainer, Push In, Fender Liner Bracket - 2/Side88970767, Retainer, Push In, Fender Liner - 5/Side88970768, Fender Sound Barrier - RH88970769, Fender Sound Barrier - LH88970770, Filler, Fender - RH88970771, Filler, Fender - LH88972194, Spacer, Wheel Opening Moulding88972303, Moulding, Front Wheel, RH88972304, Moulding, Front Wheel, LH88972305, Seal, Moulding, Gray - RH88972306, Seal, Moulding, Black - RH88972307, Seal, Moulding, Gray - LH88972308, Seal, Moulding, Black - LH94852067, Seal, Fender - 3/SideFRONT INNER STRUCTURE, FRONT88969689, Support Assy, Radiator88970715, Shield, Engine Splash, MT, Base - RH88970715, Shield, Engine Splash, MT, GT - RH88970716, Shield, Engine Splash, MT, Base - LH88970720, Shield, Engine Splash, MT, GT - LH88970727, Bracket, Upper Bumper - RH88970728, Bracket, Upper Bumper - LH88970729, Support, Headlamp Housing - RH88970730, Support, Headlamp Housing - LH88970732, Bracket, Upper Grille88970733, Bracket, Support - RH88970734, Bracket, Support - LH88970735, Reinf, Upper Panel - RH88970736, Reinf, Upper Panel - LH88970737, Bar Assy, Lower Tie88970738, Reinf, Outer Tie Bar - RH88970739, Reinf, Outer Tie Bar - LH88970740, Reinf, Frt Inr Tie Bar - RH88970741, Reinf, Frt Inr Tie Bar - LH88970742, Reinf, Rear Inr Tie Bar - RH88970743, Reinf, Rear Inr Tie Bar - LH88970744, Support, Hood Latch88970767, Retainer, Push-In - 7/Side88972195, Bar, Upper TieFRONT INNER STRUCTURE, SIDE88969691, Apron Assy - RH88969692, Apron Assy - LH88970751, Rail, Upper Outer - RH88970752, Rail, Upper Outer - LH88970753, Bracket, Rear Upper - RH88970754, Bracket, Rear Upper - LH88970755, Reinf, Inner Strut Housing - RH88970756, Reinf, Inner Strut Housing - LH88970757, Panel Assy, Front Apron - RH88970758, Panel Assy, Front Apron - LH88970759, Bracket, Front Upper - RH88970760, Bracket, Front Upper - LH88970761, Ext, Front Panel - LH88970767, Retainer, Push-In - 7/Side88970772, Seal, Fender - RH88970773, Seal, Fender - LH88970803, Reinf, Rail - RH88970804, Reinf, Rail - LH88970806, Reinf, Rear Side Rail - RH88970807, Reinf, Rear Side Rail - LH88970808, Rail, Front Inner Side - RH88970809, Rail, Front Inner Side - LH88970810, Rail, Outer Side - RH88970811, Rail, Outer Side - LH88970812, Ext, Inner Side Rail - RH88970813, Ext, Inner Side Rail - LH88970814, Bracket, Impact Bar - RH88970815, Bracket, Impact Bar - LH88970816, Rail, Rear Inner Side - RH88970817, Rail, Rear Inner Side - LH88970818, Ext, Outer Side Rail - RH88970819, Ext, Outer Side Rail - LH88972196, Reinf, Outer Strut Housing88972288, Rail Assy, Inner Side - RH88972289, Rail Assy, Inner Side - LH88972290, Bracket, Crossmember - RH88972291, Bracket, Crossmember - LHFRONT INNER STRUCTURE, SUB-FRAME88969078, Bolt, Trans Support, Rear (2)88970699, Support, Trans, GT88970700, Support, Trans, Base88970701, Support, Trans, AWD88970702, Bolt, Trans Support, Front (2)88970704, Crossmember, Front Suspension, Base/GT88970705, Crossmember, Front Suspension, AWD88970707, Bolt, Crossmember, Front (2)88970706, Bolt, Crossmember, Rear (2)88970710, Dampener, Suspension, Base/AWD88970726, Hook, Front Tow94859023, Bolt, Tow Hook (2)FRONT LAMPS 9428904, Parking Lamp/Signal Bulb 9441733, Fog Lamp Bulb/Socket88969942, Headlamp Assembly, Combo, RH88969943, Headlamp Assembly, Combo, LH88969944, Fog Lamp Assembly, RH88969945, Fog Lamp Assembly, LH88972181, Headlamp Rubber Bulb Retainer91171148, Headlamp Bulb94857194, Parking Light/Signal Bulb SocketFUEL TANK88969124, Insulator, Fuel Pump88969125, Filter, Fuel88970237, Sender, Fuel - Base, GT88970238, Sender, Fuel - AWD88970247, Tank, Fuel - Base, GT88970248, Tank, Fuel - AWD88970249, Pipe, Fuel Filler88970255, Fuel Tank Pressure Sensor (Sensor 031070)88970258, Cap Assembly, Filler88970259, Strap Assy, Fuel Tank, R - Base, GT88970260, Strap Assy, Fuel Tank, L - Base, GT88970261, Insulator, Strap, R - Base, GT88970262, Insulator, Strap, L - Base, GT88970262, Insulator, Strap, L/R - AWD88970263, Strap Assy, Fuel Tank, R - AWD88970264, Strap Assy, Fuel Tank, L - AWD88970266, Shield, Heat - Base, GT88970267, Shield, Heat - AWD88971534, Hose, Fuel Filler88971542, Shield, Filler Hose88971543, Shield, Filler Pipe88972523, Pump, Fuel94853921, Gasket, Filler Cap94856991, Housing, Fuel PumpGRILLES88969806, Upper Grille Insert, RH88969807, Upper Grille Insert, LH94853733, Retainer, Push In, Front Grilles88969808, Lower Grille Insert, RH88969809, Lower Grille Insert, LHHOOD88969690, Hood Panel88969831, Latch Assembly, Hood88969832, Handle, Hood Release Cable88969833, Cable, Latch Release88970745, Seal Assembly, Front Hood88970746, Hood Insulator88970747, Retainer Clip, Hood Insulator, Front Seal88970748, Prop Rod, Hood Support88970749, Prop Rod, Retainer Clip88970750, Prop Rod, Grommet88971412, Spring, Hood Latch, 35mm Length88971413, Spring, Hood Latch, 58mm Length88971414, Shield, Hood Latch88971416, Clip, Center, Hood Release Cable88971417, Clip, Rear, Hood Release Cable88972193, Bumper, Hood Adjust94843142, Clip, Front, Hood Release Cable94852020, Insulator, Rear Hood Hinge94852021, Insulator, Front Hood Hinge94857419, Hood Hinge Assembly, RH94857420, Hood Hinge Assembly, LHHVAC88970273, Filter, Evaporator Air88970274, Valve, Expansion88970275, Tube, Evaporator88970276, Motor, Blower88970277, Actuator, Inlet Valve88970278, Core, Heater88970279, Resistor, Blower Motor88970280, Core, Evaporator88970281, Harness, Resistor88970291, Bolt, Upper Cushion (R/L)88972198, Tube, Drain88972200, Seal, Evaporator Pipe88972202. Compressor Assembly88972204, Clutch, Compressor88972205, Valve, Pressure Release88972207, Condensor Assembly88972208, Switch, Pressure88972209, Hose, Compressor88972213, Bracket, Rear Hose88972214, Bracket, Front Hose88972216, Pipe, Evaporator88972218, Clip, Evaporator Pipe88972259, Module Assy, A/C & HeaterINSTRUMENT PANEL88970565, Blank Covers, Hatch Button Panel88970583, Switch, A/C Control88974092, Cover, 12V Outlet 2005+INSTRUMENT PANEL, RADIO94851531, Bolt, Attaches Stock Radio To Mounting Brackets94858270, Bolt, Mounts Radio Brackets To DashLIFTGATE, EXTERIOR TRIM10426379, Emblem, Pontiac Crest (Adhesive)88969818, Nameplate, "Vibe" (Adhesive)88969820, Nameplate, "Vibe GT" (Adhesive)88969821, Nameplate, "ALL WHEEL DRIVE" (Adhesive)LIFTGATE, GLASS & PARTS88969784, Liftglass Assembly88969851, Strut, Glass Support, RH88969852, Strut, Glass Support, LH88970949, Weatherstrip Assembly, Liftglass88971497, Retainer Clip, CHMSL CoverLIFTGATE, SHEET METAL88969763, Door Shell, Liftgate88969848, Strut, Liftgate Support, RH88969849, Strut, Liftgate Support, LH88970948, Weatherstrip Assembly, LiftgateREAR BUMPER88970429, Cover, Rear BumperREAR DOOR, EXTERIOR TRIM88969793, Moulding, Rear Door, RH88969794, Moulding, Rear Door, LHREAR DOOR, HARDWARE88969774, Weatherstrip Assembly, RRH88969775, Weatherstrip Assembly, RLHREAR FENDER88972309, Moulding, Rear Wheel, RH88972310, Moulding, Rear Wheel, LHROCKERS/PILLARS/FLOOR, EXTERIOR TRIM88969795, Moulding, Rocker, RH88969796, Moulding, Rocker, LH88973001, Rocker Extension, RH - 2004+88973002, Rocker Extension, LH - 2004+ROCKERS/PILLARS/FLOOR, INTERIOR TRIM88970317, Moulding, Front Door Opening, RH88970318, Moulding, Front Door Opening, LH88970319, Moulding, Rear Door Opening, RH88970320, Moulding, Rear Door Opening, LHROOF, INTERIOR TRIM88972900, Cloth Visor, RH - 200488972901, Cloth Visor, LH - 2004SEATS, REAR88970643, Fold Down Release KnobWHEELS9593883, Center Cap, 16"/17" Aluminum Wheels22676859, Wheel Cover, 16" Steel Wheel88969156, Jack88970108, Wheel, Steel88970109, Wheel, Alloy, 16x6.588970110, Wheel, Alloy, 17x788970111, Wheel, Spare88970299, Strap, Jack Storage88970724, Bolt, Spare Anchor88971024, Stem, Valve, Spare Wheel94843633, Valve Stem94850175, Handle, Jack94855294, Wrench, LugWINDSHIELD88972500, Retainer Clip, A-Pillar TrimWINDSHIELD, WIPER SYSTEM85214-01010, Insert, Wiper, LH85214-02140, Insert, Wiper, RH 88969924, Insert, Wiper, RH88969927, Insert, Wiper, LHMISCELLANEOUS88969657, Keyless Entry Remote88972631, Key, Ignition
