Carpet scrubber, interior steam clean
Posted: Wed Mar 31, 2004 12:48 am
by Mr. Poopypants
Does anyone know of a good and cheap steam cleaner out there, preferably something with an attachment so I can steam clean the VIBE? I don't want to go out and spend a crapload of $$ on a professional steam cleaner.
Re: Carpet scrubber, interior steam clean (Mr. Poopypants)
Posted: Wed Mar 31, 2004 1:49 pm
by Toasted7
I would be very interested in knowing this as well. I really need to clean the interior (seats, carpet, the whole works) of my Vibe before the MI meet. Suggestions would be greatly appreciated!
Re: Carpet scrubber, interior steam clean (Toasted7)
Posted: Wed Mar 31, 2004 3:16 pm
by AKLGT
can you rent one from a local place? i know there are some places here you can rent them for cheap for the day.
Re: Carpet scrubber, interior steam clean (trdvibe)
Posted: Wed Mar 31, 2004 4:35 pm
by Stang2Vibe
Yes, some of our local large grocery stores rent them. I have one at home that is similar to the rental ones that I always used to steam clean the interior of my cars with.I strongly recommend using a product called Dri-Clean by Blue Coral to clean the upolstry with. Its what I always used on my cars and on the cars I detailed when I did that as a side job. Poopy, you can get it at Frank's Auto Supermarket in Olympia Shopping Center. I used to get mine there all the time. It used to come in a clear spray bottle and was a pink colored liquid, I think it's still the same. I would spray it on spots to soak them and scrub them with a brush a bit, then would take the spray nozzle off the bottle and put the soap feed tube for the steam cleaner into the bottle and feed it through the machine instead of the crappy soap they sell in the grocery store where you rent the machines. Always made the interior clean up like new!
Re: Carpet scrubber, interior steam clean (Stang2Vibe)
Posted: Thu Apr 01, 2004 12:14 am
by msmyer
Quote, originally posted by Stang2Vibe »Yes, some of our local large grocery stores rent them.Yeah Kroger rents them. They are called “Rug Doctors.†Don’t hold me to this but I believe it comes with an upholstery tool.
Re: Carpet scrubber, interior steam clean (msmyer)
Posted: Thu Apr 01, 2004 8:59 am
by Toasted7
Looks like you need to hook me up there Matt! Gotta keep my Vibe clean... inside and out.
Posted: Thu Apr 01, 2004 9:40 am
by msmyer
Quote, originally posted by Toasted7 »Looks like you need to hook me up there Matt! Gotta keep my Vibe clean... inside and out. Lemme look and see if it does have one...
Posted: Thu Apr 01, 2004 10:45 pm
by Mr. Poopypants
Quote, originally posted by trdvibe »can you rent one from a local place? i know there are some places here you can rent them for cheap for the day.I want to buy one, I know Kim (my fiance) needs her car (2002 Nissan Sentra S) cleaned too.
Posted: Fri Apr 02, 2004 12:27 am
by satur9
i just bought a bissel little green clean machine today. sears new was a 100 bucks i found on refurbished at value city for 40 dollars. it might be the crappy soap they give but i treated it with armor all foaming upholstery cleaner then used the machine. it pulled out a lot of dirt. but it would lot even better professionally done. its a lot of work (my car was filthy) and im very lazy. its probably better for in between cleanings. ill try some better soap next time. but ill still get it detailed.mine has the non powered brush mabey the power brush model works better.
Re: Carpet scrubber, interior steam clean (satur9)
Posted: Fri Apr 02, 2004 3:47 am
by Mr. Poopypants
Does that little green machine thingy have an attachment hose on it or is it just a little handheld cleaner?
Posted: Fri Apr 02, 2004 5:07 am
by Stang2Vibe
I have a Bissel steam cleaner, the larger canister type (looks pretty much like a shop-vac). They used to be pretty expensive, but I think that they are pretty reasonable now. Like someone else said, try Sears. Mine has the regular attachment for cleaning the carpets in the house and a smaller attachment for cleaning funiture that I use on the car.
Posted: Fri Apr 02, 2004 5:09 am
by Mr. Poopypants
I may have to check that out.
Posted: Fri Apr 02, 2004 9:18 am
by satur9
hose and attachment. its about the size of those mini shop vacs.
