Custom retained power outlet...
Posted: Thu Mar 11, 2004 5:16 am
by Kevy Kev
..has anyone ever tried this sucessfully?
http://forums.genvibe.com/zerothread?id=2761Any pics? Please help. thanx.
Re: Custom retained power outlet... (Kevy Kev)
Posted: Thu Mar 11, 2004 5:22 am
I did
http://forums.genvibe.com/zerothread?id=6403 but didn't mess with power to the audio systems
Re: Custom retained power outlet... (joatmon)
Posted: Tue Mar 16, 2004 5:48 am
by faygolovinjuggalo
Quote, originally posted by joatmon »I did
http://forums.genvibe.com/zerothread?id=6403 but didn't mess with power to the audio systemsWhy you guys are crazy..... talk about a fire hazard.... ok here ya go.. I install alarms and remote starters for a living... relays have a purpose.... they will prevent to much amprage draw.... other wish you will burn up switches and all kind of stuff... just for an example... say you add a set of fog lamps... they pull so much power that with out a relay they burn up the power switch.... here is the easy solution to your problem... I have not done this yet but I will just for you guys this weekend... (i need too for my XBOX) chase back the power wire on your invertor. once you find it the rest is simple... cut the wire in half... the side that is hooked to the invertor run to a constant power wire. If you are unsure where one is check this website out.
http://www.bulldogsecurity.com they have it listed in the wiring diagram section. just make sure you fuse it. i dont care if it already fused. fuse it again. as close as you can to were you make your connection. a fuse cost like 5 cents.... better than burning **** up.....
Posted: Tue Mar 16, 2004 9:16 am
by Jahntassa
Yeah, we don't have a way to have that delay so the radio stays on till you open the door. Check Joatmon's thread for making the 12v outlets on all the time.Please don't follow the suggestion by Fay, reasons for this are in joatmon's thread. It would cause your battery to die constantly..
Re: (Jahntassa)
Posted: Wed Mar 17, 2004 12:01 pm
no dont listen to you..... unless you wanna burn your car up..... you will still have the damn power switch on the dash..... turn it off their when you are done..... SO NOW YOU WONT ALWAYS HAVE A DEAD BATTERY WILL YOU.... UNLESS YOUR A DUMB (removed) AND NEVER TURN IT OFF....
Posted: Wed Mar 17, 2004 12:11 pm
Easy there buddy, no need for hostility!GROUP HUG!!!
Re: (faygolovinjuggalo)
Posted: Wed Mar 17, 2004 12:18 pm
by AKLGT
hey, disagreeing with someone is fine, but we don't need to be calling anyone names. just make your points and leave it up to people to make their own decision. then they cannot blame you if they mess things up.
Re: (trdvibe)
Posted: Wed Mar 17, 2004 12:33 pm
sorry just made me mad... lol... i am over it now...
