				Wheel off set.
				Posted: Wed Mar 10, 2004 7:15 am
				by OutLaW
				I was wondering what is the biggest off set you can go on a Vibe? I'm lookin at a set of wheels and they are +42mm offset. Just not sure the clearance on the strut. Don't wanna put down that much $ and have them not fit or even rub in the corners. Thank you.
http://www.motegiracing.com/wh...desc=
				Re: Wheel off set. (OutLaW)
				Posted: Wed Mar 10, 2004 9:09 am
				by MadBill
				You should have plenty of clearance on a 7" wide wheel with 42 mm offset, OutLaW. I have 10" wides with 38 mm offset, leaving the inner flange 34 mm or ~1-3/8" further inboard than yours would be.
				Re: Wheel off set. (MadBill)
				Posted: Wed Mar 10, 2004 9:31 am
				by OutLaW
				Ok, thanks for the info. LOL. I think I should have plenty of room. I'd measure all this stuff if I only HAD my car already! It'll be here in a couple of weeks. Ordered it 1 month and 1 week ago today. grrrr, takes too long!
				Posted: Wed Mar 10, 2004 9:51 am
				by Mavrik
				my rims are a 45mm offset with no probs.
				Re: Wheel off set. (Mavrik)
				Posted: Wed Mar 10, 2004 9:57 am
				by OutLaW
				Hey, thanks for the info guys. Whats prolly the wides rims you'd be able to stuff under your car? I see you put 10" under yours. How far are you from the strut?
				Posted: Wed Mar 10, 2004 4:35 pm
				by AKLGT
				ya i saw some matrix wheels w/ 45 mm offset. sure you'll be fine.
				Re: Wheel off set. (trdvibe)
				Posted: Wed Mar 10, 2004 7:57 pm
				by Mavrik
				I'm not the only Viber with a 45mm offset cause I know someone else who has the same rims on their Vibe as I do. Of course I found out later after I bought mine. Guess someone else out there had great tastes.
				Posted: Wed Mar 10, 2004 11:52 pm
				by MadBill
				Quote, originally posted by OutLaW »Hey, thanks for the info guys. Whats prolly the wides rims you'd be able to stuff under your car? I see you put 10" under yours. How far are you from the strut?Most people would say 8" is about as wide as you can go, but as mentioned, I shoe-horned in 10" with 275/40 x 17"s. They are 4-3/4" pattern Chev wheels that I already had, so I built adaptors which give a net offset of 38 mm. The clearance to the struts and inner fender wells is only ~3/8", but I've had no scuffing there. I did have to remove my Tein springs however. Especially on the front the combination of a 2"+ drop and seven sizes wider than stock tires was just too much! If I was starting from scratch, I'd likely go for maybe a 235 or 245 on an 8" wide wheel.
				Posted: Thu Mar 11, 2004 1:21 am
				by savedbyzero
				bigger the number the more the wheels are set in the wheel well...the smaller the more the will stick out. I'm probably gonna go with either a +35 or +38 to bring the wheels flush with body. The stock seem to be inset a little more than my liking.
				Re: Wheel off set. (savedbyzero)
				Posted: Thu Mar 11, 2004 6:30 am
				by OutLaW
				Just got the call today.. My Vibe is in route to my dealer!!! Wooohooo!!
