polyurethane motor mounts.
Posted: Sun Feb 29, 2004 12:40 pm
by GT_03
Does anyone know if these exist for the Vibes??? I have several buddies in the compact car world, and all of them have these???
Re: polyurethane motor mounts. (GT_03)
Posted: Sun Feb 29, 2004 1:01 pm
by GT_03
Posted: Sun Feb 29, 2004 2:32 pm
by Stang2Vibe
It looks like they will. If you have more questions about them, you might want to call PTuning. You've got me looking at them now too.
Re: polyurethane motor mounts. (Stang2Vibe)
Posted: Sun Feb 29, 2004 9:32 pm
by GT_03
They are a must if you have a manual. Plus, you can't beat the cost. Pretty east to install also.
Posted: Sun Feb 29, 2004 11:47 pm
by MJN2
I put Energy Suspension motor moutns on my last car ('99 Cougar), and they made quite a difference. Torque steer and wheel hop were noticably lessened.Can't beat the price, that's for sure.
Posted: Mon Mar 01, 2004 7:12 am
by Jahntassa
How painful is it to put that kinda thing in? Like..what'd be required to do it?
Re: (Jahntassa)
Posted: Mon Mar 01, 2004 9:04 am
by GT_03
Not to sure, but i got a email from Ptuning.com. They will be avaiable in 2 weeks, and they will fit the Vibe. I'm getting a set
Re: (GT_03)
Posted: Mon Mar 01, 2004 10:48 pm
by cool vibes
? if you put these poly mounts in woudln"t feel the engine vibrations more? i would like to install these mounts to but?
Re: (cool vibes)
Posted: Tue Mar 02, 2004 5:54 am
by satur9
thats one of the drawbacks...it shouldnt be that bad, much better than having wheelhop
Re: (satur9)
Posted: Tue Mar 02, 2004 8:02 am
by MadBill
We better forward this link to GM so they can add these to the "Automatic Only" SC kit to quell the wheel hop that is supposedly holding up the release of the manual trans package...
Re: (MadBill)
Posted: Tue Mar 02, 2004 10:41 am
by GT_03
Madbill>>> How hard are these to install??? I figured you would probably know.
Re: (GT_03)
Posted: Tue Mar 02, 2004 10:49 am
by MadBill
I haven't looked at the Vibe's mounts, but usually they aren't too hard to change. Generally you can loosen all the bolts on one mount at a time (to keep things in alignment), put a board under the oil pan, biased towards the mount you're trying to remove and jack the engine up enough to slide the old one out and the new one in, run the bolts in finger tight, repeat with other mounts, kinda shake the engine around a bit to make sure it's "settled" on the mounts and then torque all the bolts to spec.
Re: (MadBill)
Posted: Wed Mar 03, 2004 5:45 am
by satur9
gm already knows. it was thier supposed fix for the problem.i dont know what the hold up is now.... mabey they killed to many clutches???
Posted: Wed Mar 03, 2004 8:02 am
by JohnC
I ran poly mounts in my Dodge Neon mostly due to a very poor front mount design (easily failed and oem part was $70) it vibrated the whole car. Took alot to get used to it, then finally an aftermarket mount was available so I went back to the smooooooooooth rubber. They are a must have if you do frequent launches.
Re: (JohnC)
Posted: Sun Mar 07, 2004 2:39 am
by dmitri
based on the price they look like a very good deal since i do frequent launches and i do get wheelhop at times. do they come with instructions or a diagram where the stock mounts are?
Re: (dmitri)
Posted: Tue Mar 09, 2004 5:24 am
by dmitri
anyone know?
Re: (dmitri)
Posted: Wed Mar 10, 2004 6:50 am
by Psychobroker
I dunno, but I'm ordering them right now anyway
Re: (Psychobroker)
Posted: Wed Mar 10, 2004 10:22 am
by GT_03
I just palced my order also
Re: (Psychobroker)
Posted: Thu Mar 11, 2004 1:54 am
by drummerdude
Quote, originally posted by Psychobroker »I dunno, but I'm ordering them right now anyway :-)let us know how they turn out and see if you can do step by step instructions with pics... that would be cool!
Re: (drummerdude)
Posted: Thu Mar 11, 2004 11:45 pm
by GT_03
Well, i got them in already!!! 36 hours after placed order!!!! I love ptuning.com I have to wait for some warmer weather to attempt this, but it doesn't appear too hard, only prob is the directions are just general, not for any certain make or model. Here's a pic
