Dash/center console construction
Posted: Sun Feb 22, 2004 4:29 am
by ullbergm
I know there was a great post with pictures showing how to take most of the dash/center console out of the car but i cant find it.Basically im looking to see how much space there is behind the inverter power socket. im trying to see if it will be posible to mount a small radioshack cb radio there.
Re: Dash/center console construction (ullbergm)
Posted: Sun Feb 22, 2004 4:48 am
by ragingfish
http://forums.genvibe.com/zerothread?id=5940it tells you how to remove the shifter console, but includes steps involving removal of the trim you indicated.
Re: Dash/center console construction (ragingfish)
Posted: Sun Feb 22, 2004 5:11 am
by ullbergm
thanks. exactly the thread i was looking for
Posted: Sun Feb 22, 2004 8:37 am
by Jahntassa
There's a TON of space back there...not sure if it'd be enough for you, but it's a pretty nice cavernous space... It's holding my Line-level converter, the brain to my cellphone kit, and a few other random boxes.
Re: (Jahntassa)
Posted: Sun Feb 22, 2004 9:52 am
by ullbergm
.Quote, originally posted by Jahntassa »There's a TON of space back there...not sure if it'd be enough for you, but it's a pretty nice cavernous space... It's holding my Line-level converter, the brain to my cellphone kit, and a few other random boxes.great.this thing is about 7 inches deep. thats the only direction im worried about, the others will be fine.Size:1.36 ´ 5.51 ´ 7.09 Inches (35 ´ 140 ´ 180 mm)
Posted: Mon Feb 23, 2004 12:16 am
by Jahntassa
Once you have the part of the dash that covers that space off (the plastic around the shifter and the AC controls), i'd do a fit test.. I don't think you'll have a problem with those seven inches..but i'd definitely try it before you make any modifications..
Posted: Fri Feb 29, 2008 10:38 am
by waveresponder
hmmm wonder if he ever did this...looks cool...although i like the use of the outlet...
Posted: Fri Feb 29, 2008 12:01 pm
by WaveAction
i'd do the same but instead of the cb radio i'd slap in one of those scan guages
