speaker installation
Posted: Thu Feb 19, 2004 4:23 am
by spideymike1
I'm thinking I want to upgrade the speakers in my car. I have the moon & tunes package. The problem is, I personally don't like seeing the aftermarket grills. I want the door skins to look stock. I know that there are tons of you out there that have swapped out the speakers - anyone leave the door skins they way they are? Also with the tweeters - does the OEM grill just pop off? I would love to see what speakers you all used - I am leaning toward Infinity/polk but unsure of fit. Thanks!
Re: speaker installation (spideymike1)
Posted: Thu Feb 19, 2004 4:51 am
by cohocarl
Most speakers fit under the original door "grills", with no modification.See:http://forums.genvibe.com/zerothread?id=785
Re: speaker installation (cohocarl)
Posted: Thu Feb 19, 2004 5:15 am
by spideymike1
thanks for the link - i did a search and must have missed it!
Posted: Thu Feb 19, 2004 4:35 pm
by cdFxer
My speakers are all under the factory grills-including the tweeters on the component set in the front.
Posted: Thu Feb 19, 2004 10:59 pm
by msmyer
What kind of speakers are you looking at as far as depth? Make sure you get a "lower" profile depth for the front, so that the window doesn't hit the speaker.
Posted: Thu Feb 19, 2004 11:17 pm
by dsegundo
Yeah, I'm with everybody else. you'd never know mine were aftermarket unless you look really closely.
Posted: Fri Feb 20, 2004 2:20 am
by gogoputter
I just did this in my Vibe and the oem tweeter panel pops off ...just lift from the bottom. I replaced the tweeters with Boston's and put an extra set of tweeters on the A pillars. As far as the oem grill for the tweeters once you remove the tweeter panel you can see how it is attached.
Posted: Mon Feb 23, 2004 3:38 am
by spideymike1
as far as figuring out what I was going to replace them with - i'm still up in the air. I know I have to go with something that isn't too deep - I was hoping something from Polk - Honestly as much as I want to upgrade I haven't had the time to start yet...gogo = thanks for the post - I was looking at the tweeter grill and thought that they pop from the bottom but didn't try thinking I was gonna break it. Now I know that's the way though...
Posted: Mon Feb 23, 2004 8:12 am
by Jahntassa
I have the Polk MOMO components (MM6)'s in my doors, fits behind the door panel with no problem.
