tired of waiting, so F it!
Posted: Thu Feb 05, 2004 2:27 am
by drunkenmaxx
well, i figure there will never be a catback made for the awd, so i am going to eventually just get a magnaflow muffler. would someone reccomend which would be best for my AWD?(from ptuning) Also, am i correct in thinking i have to get the muffler welded on?
Re: tired of waiting, so F it! (drunkenvibe)
Posted: Thu Feb 05, 2004 4:31 am
by drunkenmaxx
ok, now, slow down, not everybody at once...
Posted: Thu Feb 05, 2004 5:16 am
Quote, originally posted by drunkenvibe »ok, now, slow down, not everybody at once...Well, I would have told you but you're just too impatient. Maybe I'll tell you in a couple of days, if you learn your lesson.
Re: tired of waiting, so F it! (joatmon)
Posted: Thu Feb 05, 2004 5:19 am
by drunkenmaxx
ha! yeah... guess i'll just wait on one of the other of the hundreds of members!
Posted: Thu Feb 05, 2004 10:54 am
by shibaman
Take your car to a good muffler shop and have them install a magnaflow and a nice stainless tip. It will make a difference!
Re: tired of waiting, so F it! (shibaman)
Posted: Fri Feb 06, 2004 6:12 am
by satur9
you can get it done cheap with muffler clamps you can get it done RIGHT with a good weld
Re: tired of waiting, so F it! (satur9)
Posted: Fri Feb 06, 2004 10:15 am
by Roadpig
for the AWD it's the catback for the 04 GT it's the CAI....I know where you are coming from!I will wait patiently.
Re: tired of waiting, so F it! (Roadpig)
Posted: Mon Feb 09, 2004 3:17 am
by drunkenmaxx
ok, here is what i really want to know. which of these would be the best to put on my awd? http://www.ptuning.com/html/se...=2003 anyone who responds; your input is appreciated!
Posted: Mon Feb 09, 2004 7:50 am
by MadBill
Hi drunken.I'm assuming here that the AWD muffler is mounted crossways, the same as on the base and GT. If it runs parallel to the centerline on the left, ignore everything that follows. The problem with all of those "universal" mufflers is that they are designed to fit on a pipe running parallel to the centerline of the car. At 14" long for most, there isn't room on the left side for a crossover pipe from the right side to turn 90 degrees and connect. Also, the bumper mount flange hangs down quite far and the muffler might not clear. If you didn't mind carving up the plastic valence on the right side like I did with my duals [see pic (the cut's not as ugly as it looks here)], you could probably hook one up to the stock pipe just behind the axle and run it straight back on the right, but you'd likely be better off to find a muffler that had a 90 degree bend in the tailpipe(s) so it could fit crossways like the stock one.
Re: tired of waiting, so F it! (MadBill)
Posted: Mon Feb 09, 2004 9:37 am
by rcasciola
get a muffler!!! it makes a huge difference:)visit my car at:http://www.cardomain.com/id/rcasciolalet me know what u think;)
