Stock Shift Knob - loose?
Posted: Wed Jan 07, 2004 7:39 pm
by TriGuy
I've noticed that my shift knob was somewhat loose when I got from the dealer. I had to tighten it about one full turn...Anyone else notice this?
Re: Stock Shift Knob - loose? (TriGuy)
Posted: Wed Jan 07, 2004 8:21 pm
Haven't heard of anyone else having that problem -- though because it's SO easy to fix, people may not bother to mention it if it happened to them...In any case, could just have been a fluke, I wouldn't worry about it unless it comes loose again...Though I would've expected the dealer to notice it when they took it in for detailing and I'd think they would have fixed it for you...but who knows...
Re: Stock Shift Knob - loose? (ragingfish)
Posted: Thu Jan 08, 2004 8:29 am
by Mavrik
My base Vibe 5spd shifter was loose as well. I turned it by hand about 2 full turns to get it on there tight enough that it doesn't move when I shift. I kinda was glad it was loose so I could put it in just the right spot for me to feel comfortable with it.
Posted: Thu Jan 08, 2004 10:35 am
I think mine might have been a bit loose when I got it. I sometimes spin it off and back on while driving, something to do on a long commute.
Re: Stock Shift Knob - loose? (joatmon)
Posted: Thu Jan 08, 2004 10:41 am
by BubbaBlueyz
mine was loose when i got my 6 speed vibe!
Posted: Tue Jan 13, 2004 4:07 pm
by DavidPIL
Hi TriGuy...Mine was fine when I got mine but it had to be driven from another lot about 90 miles away so I'm sure whomever drove it would have tightened it.I took it in for a regular oil change and had em check the clutch and look into the notchiness. When I got it in, the shifter wasn't even lined up right. about a turn and a half to tighten it. Maybe the ones with the loose shifters, the mechanics at the dealership, maybe in a pre-delivery check, look into something under the shift boot... I know I took mine off, used a little lithium grease and Presto!, smoother shifting!Just a thought...Dave
Re: Stock Shift Knob - loose? (DavidPIL)
Posted: Tue Jan 13, 2004 4:16 pm
by AKLGT
nope. mine was fine, but then i took it off about 2 days later to paint the interior parts.... so it could've been i guess.
