				What size are the lug nuts?
				Posted: Sun Nov 30, 2003 8:45 am
				by 87iroc
				I need to buy a new socket to take the lugnuts off our 04 Vibe. It has the 16" Alloy rims. Does anyone know what size these lugnuts are? IS there any issues with fitting a impact socket in the hole? It seems to hug the lugnuts awful close.Thanks,
				Re: What size are the lug nuts? (87iroc)
				Posted: Sun Nov 30, 2003 11:54 am
				by meathead333
				M12x1.5
				Posted: Sun Nov 30, 2003 3:51 pm
				by Stang2Vibe
				Some wheels require a thin-wall socket to fit in the lug holes.  Impact sockets tend to be a bit thicker and might not fit.  Using a thin-wall socket on an impact gun usually breaks the socket when used for something with a higher torque spec.
				Posted: Mon Dec 01, 2003 11:08 am
				by 87iroc
				Thanks for the information, maybe I need to restate it though. What size of a socket do I need to purchase to fit the lug nuts?I will keep an eye on the impact socket vs. regular...
				Re:  (87iroc)
				Posted: Thu Dec 11, 2003 11:47 am
				by minivan
				The size was already mentioned above...12mm.Does anyone know if the stock lugnuts are tapered?
				Re:  (minivan)
				Posted: Wed Dec 17, 2003 10:34 am
				by minivan
				Quote, originally posted by minivan »Does anyone know if the stock lugnuts are tapered?TTTAnyone?
				Re:  (minivan)
				Posted: Wed Dec 17, 2003 10:59 am
				by cohocarl
				Quote, originally posted by minivan »Does anyone know if the stock lugnuts are tapered?Do you mean tapered where the nut contacts the wheel?  If so, yes they are so the wheel will center on the hub.
				Re:  (cohocarl)
				Posted: Thu Dec 18, 2003 10:52 am
				by minivan
				Thanks!
				Re:  (minivan)
				Posted: Tue Dec 23, 2003 9:00 am
				by 87iroc
				Quote, originally posted by minivan »The size was already mentioned above...12mm.Does anyone know if the stock lugnuts are tapered?  I found out and thought I would post...I need a 21 mm socket to pull off the lug nuts.12 mm is the thread size...
				Re:  (cohocarl)
				Posted: Wed Dec 24, 2003 9:00 am
				by 87iroc
				For what it's worth, I just rotated my wife's tires and the lug nuts are the type that go down inside the rim. We have the 16" aluminum up-level rims...
