Spare Tire Pressure Check
Posted: Thu Oct 02, 2003 11:24 am
by RoundUp
Just out of curiosity, does anyone check the pressure of their spare regularly? I check my tires at least once a month, but I only checked the spare today for the very first time. And it's a pain! Had to move everything out of the back, take the spare out and flip it over to do the check. I did this in my parking spot. Can't imagine doing this regularly at the gas station when I adjust the other tires.
Re: Spare Tire Pressure Check (RoundUp)
Posted: Thu Oct 02, 2003 11:27 am
by meathead333
thatd be the reason why i have never checked mine, i am too lazy to move everything out.
Posted: Thu Oct 02, 2003 11:47 am
I haven;t done it in my Vibe yet, but it is a good idea to do it periodically. Didn't check it on my last car, and I can testify that it really sucks to try to replace a flat tire with a flat spare.At least I still have a couple months of 1800ROADSID left.
Re: Spare Tire Pressure Check (meathead333)
Posted: Thu Oct 02, 2003 11:49 am
by MadBill
Maybe you can just give it a squeeze or a bounce with a hammer every so often, to see if it's gone soft. Big rig drivers develop a good feel for how a rubber hammer (or even the toe of a boot) should bounce off their 18 plus tires...
Posted: Thu Oct 02, 2003 2:34 pm
I check it once in a while...but not often...
Posted: Thu Oct 02, 2003 4:47 pm
by Lancer
Mine is in the basement until the snow starts to fly.
Posted: Thu Oct 02, 2003 10:46 pm
by NovaResource
Griot's Garage has is the answer to your problem:EASY ACCESS, SPARE TIRE AIR LINESpare tires that are remotely located should be checked periodically for correct tire pressure. Here's a way to conveniently check the pressure and fill the tire without even lifting the carpet! Connect our Spare Tire Airline to the spare tire's valve, and its long 42" length will extend into the trunk or luggage area. Use a tire gauge to check your correct pressure. If it's low, add air pressure as you normally would on the same end! No more useless, flat spares! Red hose for easy visibility. Indispensible for hard-to-reach spare tires. 44407 Spare Tire Air Line $9.95
http://www.griotsgarage.com/catalog.jsp ... &SKU=44407
Re: Spare Tire Pressure Check (NovaResource)
Posted: Fri Oct 03, 2003 12:43 am
That's pretty cool.
Posted: Fri Oct 03, 2003 12:13 pm
by RoundUp
Must say that I am impressed!
Posted: Wed Aug 17, 2005 10:48 am
by GMJAP
I was checking my tires today and figured I should check the spare too. Man, it is a pain in the (removed)! (Still in the 05!) You can't get to the spare air stem without taking the darn spare completely out.So I found this ancient thread. I'll have to check and see if that Air Line is still around.
Posted: Wed Aug 17, 2005 11:55 am
by zionzr2
i think i may have to get a couple of those.then i would actually be more inclined to check...as it is now i do not I also hate dougnut spares....I miss having a full-sized spare!!
Re: Spare Tire Pressure Check (GMJAP)
Posted: Wed Aug 17, 2005 10:29 pm
by Baltovibe
Quote, originally posted by GMJAP »I'll have to check and see if that Air Line is still around.Didn't find it at Griotsgarage, but did find a similar one called Chek-A-Spare.
http://www.getagauge.com/USAProducts.cfm
Posted: Wed Aug 17, 2005 10:43 pm
by zionzr2
yep found the same one and its only $6
Posted: Wed Aug 17, 2005 10:51 pm
by Pick
I have no reason to check it's pressure, i carry an air pump in there, plus plugging tools to fix a flat so i don't even have to bother using the spare unless i totally destroy a tire.
Re: Spare Tire Pressure Check (Baltovibe)
Posted: Thu Aug 18, 2005 12:21 am
by GMJAP
Quote, originally posted by Baltovibe »Didn't find it at Griotsgarage, but did find a similar one called Chek-A-Spare.
http://www.getagauge.com/USAProducts.cfm Thanks for posting that, Baltovibe! Great price too.I also carry an air compressor; maybe I'm just a little over-cautious once having had a flat and finding my spare flat too. If it's easy to check I think it's worth it once in a while to make sure the spare is okay (hasn't gone totally flat.)
Posted: Thu Sep 08, 2005 6:46 am
by zionzr2
just ordered 2EDIT: 1 for the vibe and the other for my wife's car!!
Posted: Thu Sep 08, 2005 9:22 am
by northvibe
now if we could only find a way to make them spin with out coming off and just have a pump in your trunk then u could have run flats!!
Posted: Mon Sep 12, 2005 2:50 am
by zionzr2
WOW fast shipping!!Ordered Thursday about 5pm recived via mail Saturday!I routed it to the drivers side storage bin. very easy access..Showing the spares location and the path of the new hose.Storage Bin shot
Re: Spare Tire Pressure Check (zionzr2)
Posted: Mon Sep 12, 2005 4:22 am
by Baltovibe
Quote, originally posted by zionzr2 »just ordered 2Thanks, Zionzr2! I was procrastinating on this item, but after seeing your success, I just ordered 2 also. Great routing job and pics! Thanks again!
Re: (zionzr2)
Posted: Mon Sep 12, 2005 6:22 am
by GMJAP
Nice job, zionzr2!I routed mine up to the hand-hole in the middle of the bumper side of the cargo floor. Probably not a very good description; maybe I'll get a pic too.
