04 Base - Gas smell under car
Posted: Wed Sep 17, 2025 9:14 pm
by Nica1Vibe
When I park my base 04, I can smell gas. Some time prior to this I used to have a small evap leak, changed the gas cap, code went away. I put the car up, ran it, let it sit, visually inspected everywhere I could, found no sign of a fluid leak, and didn't smell anything while it was running. The smell is noticeable inside the car, just outside near the rear end.After the car had been running I could smell it. Could this be a bad tube from the tank to the charcoal canister or a bad canister?
Hooked up a scan tool and there are no codes found.
There is also no gas smell under the hood.
Has anyone had this problem before? Please share your ideas on this.
Re: 04 Base - Gas smell under car
Posted: Sat Nov 01, 2025 2:24 am
by FrankenVibe
This seems similar to an issue I had. Turns out 3 of the lines from the Charcoal Canister to the tank were eaten through. I swapped two of them out, the third has a fuel connector on the canister side and I don’t know where it goes, so I still have to find a solution for that. But I’m certain one of those damaged lines is where the slight fuel smell after driving is coming from.
https://imgur.com/a/eaten-evap-line-3-OPr93Tb
Posted: Sat Nov 01, 2025 10:00 am
FrankenVibe wrote: ↑Sat Nov 01, 2025 2:24 am This seems similar to an issue I had. Turns out 3 of the lines from the Charcoal Canister to the tank were eaten through. I swapped two of them out, the third has a fuel connector on the canister side and I don’t know where it goes, so I still have to find a solution for that. But I’m certain one of those damaged lines is where the slight fuel smell after driving is coming from.
I totally agree with Franken. Had rodents chew through some of mine 7-8 years ago. I had codes too, but since making repairs AND replacing charcoal canister a year or so later (see this post: viewtopic.php?f=17&t=47004&p=527026&hil ... er#p527026 ) I still have codes :evil:
