Fuel Rail Assembly
Posted: Wed Jan 01, 2025 7:39 am
by chrisblues12
My mechanic says the fuel rail assembly in my '04 Vibe is leaking.
Part is discontinued and we can't seem to find a used one locally.
2004 Vibe, 1ZZFE
part 19205530 - https://www.gmpartsgiant.com/parts/gm-r ... 05530.html
Anyone have any idea where else I can look?
I see two on ebay but I can't tell if either is the right one or not.
https://www.ebay.com/itm/256404847130
https://www.ebay.com/itm/364872250954
Re: Fuel Rail Assembly
Posted: Wed Jan 01, 2025 10:03 am
by andrewclaus
You'll probably have better luck using the Toyota part number to search. I use this site http://www.japan-parts.eu/toyota/us/. Use your VIN or model info. My 2007 part number is 23807-22030 and there are lots of options, new and used.
Posted: Thu Jan 02, 2025 4:31 pm
by chrisblues12
Dumb question but are the Matrix parts interchangeable for the Vibe?
I know they're basically the same car.
So for my 2004 Vibe, I can just get a 2004 Matrix part for what I need?
Posted: Fri Jan 03, 2025 12:06 am
by jolt
chrisblues12 wrote: ↑Thu Jan 02, 2025 4:31 pm Dumb question but are the Matrix parts interchangeable for the Vibe?
For the most part, the cars are the same. GM did use and do some different things to the Vibe then the Matrix. The obvious is the body and interior parts. When it comes to the other parts, GM used their own radio system, A/C and heating system in the Vibe. So these system parts do not interchange. Because of the different systems, the wiring can be different or different color wires between the two makes. Most other parts are the same, so Toyota is a good source, if the part can not be found from other sources.
