04 Vibe timing chain replaced now stalling at low rpm
Posted: Tue Oct 29, 2024 8:55 am
by Hotzjoe90
Hey everybody. So I have an 04 vibe 1zz with over 400k miles and recently changed the timing chain out. After installation my car is stumbling at low rpm and when I put it in gear. I have a spark advance of 13 at idle, and runs way to well for timing to be off I would think. Please help!:
Re: 04 Vibe timing chain replaced now stalling at low rpm
Posted: Mon Nov 11, 2024 8:29 pm
by lexicon
Would like to find out if the chain was off a tooth.....
any update ?
All electronics connections ok ?
Posted: Thu Nov 14, 2024 12:36 pm
welcome to genvibe.
I haven't been able to find a reference that specs a timing advance for a 1zz, only thing I can find is a procedure for chain replacement (attached) , and it describes the timing chain and gear alignment at step 26, but that's nothing you can verify from outside the engine
What are the RPMs where it stalls? (is it a problem with it stalling at idle, or a problem of idle too low?)
