Replaced ABS Sensor on both front wheels but..
Posted: Mon Jul 29, 2024 7:24 pm
I replaced the abs sensors on both my front wheels to fix an issue I’ve had since putting snow chains on improperly which damaged them. Today I replaced the one the passenger side and everything seemed good after, no dashboard lights but then suddenly they all returned (abs vsc, traction)
What should I do next and is there anything else I should check? I really want to fix this issue. I did overtighten the bottom screw when installing the bottom sensor which made it crack a little but still was on securely, could that have damaged it causing the lights?
