Just the Right Turn Signals
Posted: Mon Jul 15, 2024 6:43 am
I need help. My car has an issue with right turns. I've searched through the forums and can find a lot of turn signal issues, but nothing like this. The turn signals on the right (front and rear) side are no blinky. But when I turn the lights on, I get the DRL/side marker light. The left side blinks fine. Oh and no hyper flash to indicate a burnt bulb.
Here's what I've done:
1. Swapped bulbs and sockets from right to left.
2. Checked the only fuse I could find, Hazard in the fuse box under the hood.
3. Cleaned the ground.
4. Checked power at the socket.
a. Power to the DRL side.
b. No power to the Turn side.
5. Replaced the relay flasher.
5. Replaced the turn signal switch.
I just purchased a Test Light,3-60V DC Bidirectional Voltage Circuit Tester... I just don't like just poking around. Starting point?
