Engine Light Stuck On
Posted: Sat May 11, 2024 1:37 pm
I have a 2006 Vibe with 120K kms (75K miles approx). In 2017, the engine light came on after gasing up in the pouring rain. Seven years later, light still on. I need to resolve this in order to 'import' the car to a new province: it will not pass the out-of-province inspection with the light on.
Rendering the vehicle almost worthless not to mention, I want to continue driving this car for a long time to come.
To date:
- In 2017, soon after the engine light came on, the GM dealer spent 4 hours on it when replacing the PCM/recall, couldn't find the issue and told me to drive it until it drops (um, yeah, all good until it needs an inspection)
- Replaced the gas cap (online trouble shooting pointed to that as a potential problem/solution - vapor lock when gasing up, etc)
- independent mechanic spent 2 hrs and the code reading was that the VIN could not be found...
- another indepedent mechanic took a shot at it, again no resolution and wonky codes.
Since the light came on, I've personally driven it a large distance across the US, coast-to-coast in Canada a couple times, and would not hesitate to jump in it tomorrow and drive it coast-to-coast again. There is nothing wrong with this car. It's the most reliable versatile vehicle I've owned and I'd really like to find a way to solve this. I appreciate any ideas. (Disconnecting it to pass the inspection is not a solution that will work.) Edited to add: VStability Light came on at same time. No issues there either, but noting cause it came on at same time - and remains on.
To date:
