comparment under shift stick
Posted: Wed Jan 24, 2024 5:22 pm
by salamander162
Hello everybody?
i own a 04 vibe gt and little by little i'm fixing some issues but the compartment under the shift stick keep opening, i does not keep closed at all, is there are any missing part/s?
thanks for any help on this matter
Re: comparment under shift stick
Posted: Thu Jan 25, 2024 7:29 am
I found three threads about this:
viewtopic.php?t=28793 Front storage door below shifter will not stay closed.
viewtopic.php?t=9617 Loose storage tub under the shifter.
these first two reference another thread, as "ht
tp://forums.genvibe.com/zerothread?id=777" but that's from before the forum software changed, so that zerothread link doesn't work, but thanks to the internet archive wayback machine, I was able to identify it as the third promised thread:
viewtopic.php?t=560 Storage compartments rinky-dink closures: SOLVED!
hope they help. That third one was from member NovaResource, who hasn't been here for a really long time, but when he was here he was an invaluable source of info and insight.
My problem with that compartment was that when I pressed the release button, it wouldn't drop open, so I had to hook a thumbnail in the seam on the side when pressing the button and then pull it open.
Posted: Sat Jan 27, 2024 6:53 am
by salamander162
thank you very much, i feel dumb that it was that easy to solve the problem ,
