Matrix Radio in old GA
Posted: Thu Sep 18, 2003 1:07 pm
by ragingfish
I just bought a Matrix radio I want to install in my dad's 98 Grand Am.Anyone know, since this radio is made by delphi/delco whoever...if I need an adapter harness to go from GA wiring to radio, or if the harnesses have been relatively consistent the last 5 years or so?His radio has theftlock, and i think 6 speakers, if that makes a difference?
Re: Matrix Radio in old GA (ragingfish)
Posted: Thu Sep 18, 2003 10:45 pm
by Sub-Vibe-R
I had a 01 Montana with a Delco unit and I used the same wiring harness in my Vibe. So I presume the wiring harness will be the same as well.
Re: Matrix Radio in old GA (Sub-Vibe-R)
Posted: Fri Sep 19, 2003 1:19 am
by Vibe Rater
It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.
Re: Matrix Radio in old GA (Vibe Rater)
Posted: Fri Sep 19, 2003 1:22 am
by drunkenmaxx
quote:It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.that is an excellent theory
Posted: Fri Sep 19, 2003 1:35 am
by meathead333
quote:It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.that was deep.
Re: Matrix Radio in old GA (meathead333)
Posted: Fri Sep 19, 2003 2:01 am
by Sub-Vibe-R
The wiring harness should fit, but may be the bracket to screw the radio in hte dash will not fit.
Posted: Fri Sep 19, 2003 7:19 am
by ragingfish
quote:The wiring harness should fit, but may be the bracket to screw the radio in hte dash will not fit.Is it possible to obtain a mounting kit for a matrix radio to go into the GA?Derek -- how did you mount the vibe radio in the kia?
