1ZZ-FE Valve Cover Replacement Tip
Posted: Wed Jan 20, 2021 12:14 pm
by TYK97
I'm using my daily 03 Vibe Base (130K miles) to learn more about working on cars. Recently I purchased a used valve cover from a wrecked Vibe. It looks like it is in good condition.
I am replacing the PCV valve, valve cover, gasket (+2 grommets), and have gasket maker for the part between the cams and timing chain. I already replaced spark plugs at 120k miles.
My question is do I need to oil up the new valve cover as like a primer? Should I wait to change the valve cover the same time I change the oil? Does anyone have any tips or things to look out for when doing this work? I have owned the car for roughly 55-60k miles and this is the 1st time I am doing the valve cover gasket.
Thank you all. I'm including a few pics of the new valve cover.
Re: 1ZZ-FE Valve Cover Replacement Tip
Posted: Wed Jan 20, 2021 1:41 pm
TYK97 wrote: ↑Wed Jan 20, 2021 12:14 pm
You want to make sure all the mating surfaces are oil free. Sometimes I use a paper towel I've sprayed with brake cleaner to clean surfaces like that.
The valve cover doesn't retain any oil, so there's no need to prime it with oil.
The only reason I can think of to synch the cover change with an oil change would be if you drop crap into the engine, something like you weren't careful enough removing the old sealant at the timing chain/head seam, then perhaps after running the engine a bit to wash the debris into the pan, changing the oil. But we'd all agree it would be a lot better to avoid dropping debris into the engine, so do that and don't worry about tying it to an oil change.
Here's a pic from the 03 Matrix manual about replacing the valve cover, there's no specific torque pattern, but it does give the bolt torque specs. 8 ft-lbs isn't a lot.
- Covertorque.jpg (64.42 KiB) Viewed 16053 times
Curious, why do you need a replacement valve cover?
Posted: Wed Jan 20, 2021 4:50 pm
by TYK97
https://forums.genvibe.com/phpBB3/viewt ... 12&t=47633
This is also me lol. I know a replacement valve cover was kinda the last thing to try but it just seamed like the easiest to me while also helping me learn more about the car and the engine.
Posted: Thu Jan 21, 2021 7:10 am
I remember now. Replacing the valve cover would be easier than mucking about trying to restore the stripped threads.
Should be pretty straightforward task, but sometimes I find a way to turn an easy task into an ordeal. The last time I pulled the valve cover, the one stud that acts as both a valve cover bolt and a mount for the plastic engine cover came off with the engine cover. Instead of unscrewing the acorn bolt holding the engine cover on, the stud came out of the head. When I went to put the valve cover back on, I spent an embarrassing large amount of time looking everywhere for the one valve cover screw that I had somehow lost. Finally found the stud still attached to the plastic engine cover.
Posted: Tue Jan 26, 2021 3:47 pm
by TYK97
I am going to head over to ace and get some replacement bolts for the coil packs. Do you know which ones I need and which material they should be? I'm not positive but I am under the impression the torque spec changes with the bolt material used.
Thank you
Posted: Tue Jan 26, 2021 6:29 pm
yes and no. Different materials have different strengths, so they'll have different maximum torque before they shear or strip. The matrix manual says the torque for the ignition coil bolts is 80 inch pounds which is snug but not really that tight. At 80 in-lbs the type of material isn't going to matter much, you won't shear it off, and shouldn't strip the threads. I don't know what the OEM bolts were made of, but I might go for stainless steel just to prevent any corrosion. Just don't over torque them
Posted: Thu Jan 28, 2021 9:13 am
by zbyers
OEM valve cover bolts are an M6x1.0... about 35mm in length.
Posted: Thu Jan 28, 2021 9:28 am
Do you know what size the ignition coil bolts are?
Posted: Mon Feb 01, 2021 8:30 am
by zbyers
joatmon wrote: ↑Thu Jan 28, 2021 9:28 am
Same thread...Maybe a little longer. But probably the same.
