Good fixing chemicals/ideas for vibrations....
Posted: Wed Dec 30, 2020 12:45 am
by cbusenke
I've got a 2004 Vibe, base model, the car is still kicking (removed) at around 400k miles. However, the dash has been opened up, Often. It's been a real pain in the (removed) to find out where the cables to the a/c system attach to the back of the dials. More than that, I'd really like some ideas on what I could put in between pieces of plastic in the same module or in between the clear lenses that cover the gauges on the dash panel and the silver framing around them. If you've taken it apart you know what I mean
Re: Good fixing chemicals/ideas for vibrations....
Posted: Thu Dec 31, 2020 6:08 am
by SSizler
I got a OEM Toyota noise kit, PN: 08231-00801
It has some handy adhesive backed foam and felt sheets that solve many rattle problems.
Here is a link with a photo:
http://www.2040-parts.com/genuine-oem-t ... --i687928/
Good luck!
