1zz-fe cylinder head oil return passages
Posted: Mon Oct 19, 2020 7:00 am
by EW57
Greetings, could someone tell me approximately how many oil return passages there are in a 1zz-fe and where they're located? I'll attempt to attach a representative photo.
Thanks & take care
- 1ZZ-FE_w_head_800.png (66.53 KiB) Viewed 2867 times
Re: 1zz-fe cylinder head oil return passages
Posted: Mon Oct 19, 2020 3:43 pm
by CNYDave
I would say, look at the 3 brown passages on this block, just those and the cam chain passage.
then match up with a cylinder head pic, I think I see 3 next to the head bolts at top of pic
Posted: Mon Oct 19, 2020 4:16 pm
CNYDave wrote: ↑Mon Oct 19, 2020 3:43 pm
http://www.corollaforum.com/threads/how ... down.6726/ has a pic of the underside of the head that came off that block
I don't know how /what oil returns there are from the top of the head that drain into the chain area
edit I also attached a PDF from the 03 matrix manual about the 1ZZ lubrication system, has a couple of interesting pictures
Just curious, what circumstance prompted the question?
Posted: Tue Oct 20, 2020 6:51 am
by CNYDave
just behind the sprockets would fill fill oil if there weren't a drain, so I'm pretty sure there is one.
Light looks to be coming through a possible opening in this pic:
Posted: Tue Oct 20, 2020 5:19 pm
by EW57
Thank you everyone for your input, excellent info!
