Matrix awd article
Posted: Tue Sep 09, 2003 10:57 pm
by Chris
Hi all... for anyone who's interested, here's an article/test drive of the Matrix AWD on Canadian Driver. IF you are not clicking through today (Wed Sept 10) you can find the write up in the 'archives'Have a good one!
http://www.canadiandriver.com
Re: Matrix awd article (Chris)
Posted: Wed Sep 10, 2003 12:25 am
by NSimkins
Thanks for the post! For those that don't see the article on the front page of CanadianDriver, here is the direct link to the article:
http://www.canadiandriver.com/roadtest/03matrix_4wd.htm
Posted: Wed Sep 10, 2003 8:46 am
by ragingfish
Correct me if i'm wrong, but i thought these were ALL wheel drive cars ,not 4WD? Isn't there a difference???
Re: Matrix awd article (ragingfish)
Posted: Wed Sep 10, 2003 8:55 am
by millster
You're write, it's all just wording here. To my knowledge, Toyotas have always been called 4WD, so I guess they just wanted to stick to convention.
Re: Matrix awd article (millster)
Posted: Wed Sep 10, 2003 8:59 am
by ragingfish
I thought I remember someone saying 4WD is full-time, 4 wheel drive, where as AWD is on-demand traction...but whatever, what's in a name, right?
Posted: Wed Sep 10, 2003 9:02 am
by millster
That's how I would think of it, but the Matrix is indeed the same system (unless I'm mistaken) and I've always seen Toyotas called 4WD. You're right, I guess there's nothing in a name sometimes.
Posted: Wed Sep 10, 2003 9:13 am
by philndz
yes...you are very correct raging....big difference between 4wd and awd....4wd is not very practical on the streets and not economical either...but on the flip side it will generally outperform awd systems on the rough stuff....although some of the really techy awd systems coming out have the advantage of computer control and can be very effective off road...ie. landrovers and mercedes and such.
Posted: Wed Sep 10, 2003 9:14 pm
by Hot Vibe
Here is a quote from the article.QUOTE:"The base Matrix 4WD receives air conditioning, a clean air filter and keyless entry as standard equipment."I hope to hell after paying $20000 you get a clean air filter.
Re: Matrix awd article (Hot Vibe)
Posted: Thu Sep 11, 2003 1:37 am
by drunkenmaxx
quote:Here is a quote from the article.QUOTE:"The base Matrix 4WD receives air conditioning, a clean air filter and keyless entry as standard equipment."I hope to hell after paying $20000 you get a clean air filter. i'm pretty sure that is refering to the HEPA air filter that cleans the air coming out of the vents. i may be wrong...
