Would like a bluetooth + better stereo installed
Posted: Sun Feb 17, 2019 2:28 pm
by RubyVibes
Hello all!
I recently purchased my first Vibe (06) and couldn't be happier! I am in Reno, NV. There are a few little things wrong with it that I will fix over time, but getting the stereo updated is one of the first. This forum has been sooo helpful; I chose the car I did out of 6 potential ones with the information supplied by enthusiasts. Thanks to everyone for being so generous with your time and knowledge.
Here is my situation. I have a stock stereo and speaker set-up. I'm no sound buff, so it sounds ok to me. I would like to have bluetooth set up though, so I can listen to podcasts and whatnot from my phone on my long commute. I have combed through the threads in this category and am bowled over by all the awesome stereo and speaker set ups, often DIY. I was getting some replacement parts at an auto store the other day, and the cashier said he bought a system at Best Buy and they installed it for him and it's a whole lot better. I have never done electrical work, so this sounds like a more attractive route to me.
I am looking to spend no more than 400 total for a stereo/speaker upgrade. I'm sure I could figure out some basics of installation, but simply don't have the time for another project, and don't mind paying to have one less thing on my plate. Does anyone have any experience/suggestions of a good system for this budget? Of course, sounding better and being reliable would be great :)
Thank you in advance!
Ruby
Re: Would like a bluetooth + better stereo installed
Posted: Sun Feb 17, 2019 4:17 pm
by Mark
I was going to do the same thing, but then I went a different route and bought one of these https://www.amazon.com/gp/product/B07JV ... UTF8&psc=1 instead. I use the iHeartRadio app to stream my favorite station (KBCO), saved me a ton of $$$.
Posted: Sun Feb 17, 2019 4:49 pm
by SlammedNiss
Installing just a new head unit is a pretty simple task. I would highly consider looking at www.crutchfield.com as they will include all dash kits and harnesses to install your new radio. All wires are color coded so getting it wrong would be difficult. All you would need is some crimpers and connectors which if you dont already have, can be purchased for cheap at any hardware store.
Posted: Mon Feb 18, 2019 4:51 am
by zbyers
SlammedNiss wrote: ↑Sun Feb 17, 2019 4:49 pm Installing just a new head unit is a pretty simple task. I would highly consider looking at www.crutchfield.com as they will include all dash kits and harnesses to install your new radio. All wires are color coded so getting it wrong would be difficult. All you would need is some crimpers and connectors which if you dont already have, can be purchased for cheap at any hardware store.
I agree with SlammedNiss. Crutchfield is a go-to if you are replacing the headunit.
Posted: Mon Feb 18, 2019 5:12 am
by andrewclaus
Another vote for Crutchfield. The kit worked fine. Spend as much as you can on a decent unit--I bought a bottom-line model and got exactly what I paid for. I don't spend much time in the car, so it's okay.
Posted: Tue Feb 19, 2019 12:29 pm
by RubyVibes
Thank you all so much.
Crutchfield looks awesome, what a neat resource. I believe that I can figure out how to get the head unit in. I would also like to get speakers in as well if I'm going to upgrade it. Is that something that needs to be done at the same time? Would you recommend getting someone to do that? I don't have any electrical skill and don't mind paying to have a good job done with no hassles.
Thanks again.
Posted: Tue Feb 19, 2019 1:06 pm
by SlammedNiss
If you can take apart the door panel, then changing out the speakers is a pretty painless job as well. The hardest part is getting the old speakers out. They are held in with rivets that will have to be drilled out. After that, it's just a matter of attaching the new wires and screwing the new speakers into the door.
With that said, I'd replace the head unit first. You might be pleasantly surprised how much better it sounds with just a new head unit still using the OEM speakers.
Posted: Tue Feb 19, 2019 6:42 pm
by ColonelPanic
SlammedNiss wrote: ↑Tue Feb 19, 2019 1:06 pm
Couldn't agree more! If the speakers haven't rotted out and still work fine, it's definitely worth a try.
We'd still have the OEM speakers in if they wouldn't have been damaged by water.
Posted: Sun Feb 24, 2019 8:53 pm
by RubyVibes
Thank you very much!
I'll let you guys know how it goes!
Posted: Sun May 26, 2019 10:22 pm
by RubyVibes
Hey guys!
Did it! Thanks for all the recommendations. Went the Crutchfield route, and it's been a pleasure. Will try to upload a photo.
Thanks again!
Vibe stereo.jpg (101.86 KiB) Viewed 4525 times
Ruby
Posted: Tue May 28, 2019 2:53 pm
by ColonelPanic
Good job on the install, it looks great!
That's quite the stealth mounting location for the bluetooth mic. How's the sound on the other end when running the fan?
