How do you get to the spark plugs?
Posted: Wed Sep 03, 2003 2:18 am
by vibenorth
I changed my oil the other day and thought I'd take a look at the spark plugs, and realized I wasn't sure how to get to them. I couldn't find any info in the manual.
Re: How do you get to the spark plugs? (vibenorth)
Posted: Wed Sep 03, 2003 2:25 am
There's a thread that has some good pics of the spark plug access at
http://forums.genvibe.com/zerothread?id=5814, and an ongoing discussion of which plugs are best for a Vibe.It's different than other cars I've had.
Posted: Wed Sep 03, 2003 11:14 am
by champcaracing
both engines you will need to remove the engine cover (black plastic) should be 2 10mm nuts in front and 2 plastic clips in the rear (1ZZ engine) the 2ZZ .....should be 4, then unplug the coil packs, remove the 10mm bolt. and you now have access to the plug.
Re: How do you get to the spark plugs? (champcaracing)
Posted: Thu Sep 04, 2003 1:26 am
by vibenorth
How are the clips removed?
Posted: Thu Sep 04, 2003 5:02 am
by engine1
Just use a small bladed screwdriver to pry up the center then it can gently popped out of the cover1
Posted: Thu Sep 04, 2003 9:41 am
by champcaracing
i lift the cover up in front and sorta roll the cover back...SLOWLY not to break the clips. i have used the screw driver before and break them sometimes.
