Dash rattle
Posted: Fri Aug 29, 2003 12:12 pm
by GT Guy
Is there a service bulletin # for this problem??
Re: Dash rattle (GT Guy)
Posted: Fri Aug 29, 2003 12:13 pm
AFAIK, no bulletin, but most have confirmed it's the DRL relay module rattling...
Posted: Fri Aug 29, 2003 12:47 pm
by Merzbow
I have one of those, it is coming from the right side of the gauge pods sounds like a sticking sorta rattle? -=Paul=-
Posted: Fri Aug 29, 2003 1:30 pm
by Toasted7
I have a dash rattle as well. Just started a few months ago and it's coming from the left side of the steering wheel, behind the storage compartment. If I open the up and push up against the top of the compartment, it usually stops, but if I let go... it will start "buzzing" a few seconds after that. It's really starting to (removed) me off (when I don't have my stereo cranked up that is). Anyone else have this issue or any suggestions for me to fix it???
Re: Dash rattle (Toasted7)
Posted: Sat Aug 30, 2003 1:16 am
My dash rattle is from the top left , about where the light sensor is . It's not the sensor, becuase I took that out, made no difference, so I put it back. Seems to only happne when cold, so hasn't been a problem much lately. Can get it to stop if I push down on the leading edge of the dash, right by the windshield in the left corner.I will probably take it in to a dealer to get it fixed before the warranty runs out.
Posted: Sat Aug 30, 2003 12:14 pm
by P POPPR
quote:I have a dash rattle as well. Just started a few months ago and it's coming from the left side of the steering wheel, behind the storage compartment. If I open the up and push up against the top of the compartment, it usually stops, but if I let go... it will start "buzzing" a few seconds after that. It's really starting to (removed) me off (when I don't have my stereo cranked up that is). Anyone else have this issue or any suggestions for me to fix it???Exact same situation here. So far we only have 1300 miles on the car. After we put on a few more miles on it we plan to have the dealer care for that noise and any other things that come up. So far that noise is the only complaint.
Re: Dash rattle (P POPPR)
Posted: Sat Aug 30, 2003 2:21 pm
Good luck. Had my car @ the dealer 3 times for rattles. The last time I took the service guy on the road, he acknolwedged them, and I STILL got the car back with "NPF: NO PROBLEM FOUND" or "UNABLE TO REPRODUCE CUSTOMER CONCERN" bullsh*t on it...
Re: Dash rattle (ragingfish)
Posted: Mon Sep 01, 2003 1:37 am
by DeClerq
We've got one as well, though it seems to originate from the right side of the dash and only when accelerating. Haven't really investigated it yet, but will probably get it checked out when I have the alignment issue taken care of.
Posted: Sun Aug 07, 2005 11:06 pm
by northvibe
DeClerq - did you find out what it was? wow this post is old but, i get a weird rattle/vibrating when i accelerate, ill have to investigate where it is this week. I know its either in my engine compartment or far into the dash.
Posted: Thu Nov 24, 2005 9:40 am
by Summer
If you have a mysterious "dash" rattle and can't locate the source, check the map lights in the rear-view mirror.
Posted: Thu Nov 24, 2005 11:17 pm
by Atomb
i've become quite adept at my 'kung-fu dash smack' accuracy.i find a quick jab or an upper-cut to specific locations does a good job of fixing rattles...
Re: (Atomb)
Posted: Fri Nov 25, 2005 12:57 pm
by mcgusto82
my radio bezzel likes to vibrate/hum at high RPM.i put some electriccal tape around the crips. it's muzzle it down.
Posted: Wed Dec 07, 2005 9:12 am
by thermometer
Sometimes the rattle is from the silver trim around the gauges
