Pos or neg horn connection to steering wheel switch?
Posted: Wed Jun 29, 2016 6:07 pm
by BenWA
I ordered a set of Hella Sharptones (yellow). I will be installing them sometime in the next week. However, I see that I need to know if the horn is connected to the steering wheel switch with positive or negative. How is the 03 Vibe's horn connected?
EDIT: I'm now pretty sure it's positive (the wire that connects to the stock horn is what is best to feed from for the Hella's relay) but I'll still wait for a reply.
Re: Pos or neg horn connection to steering wheel switch?
Posted: Wed Jun 29, 2016 10:06 pm
by jolt
Here is the horn wiring in the pdf file that is attached.
026hs.pdf
Horn wiring 2003
(14.13 KiB) Downloaded 194 times
Posted: Thu Jun 30, 2016 10:57 am
by BenWA
Yeah it looks like the wire at the factory horn is positive, not ground. Ground is fed from the mounting bracket.
Thanks.
