Removing EVAP, any computer tuners here?
Posted: Mon May 02, 2016 6:29 am
by samsonite
I want to completely remove the EVAP system on my car and just have it vent to the atmosphere. Is there anyone here who could remove the codes from the PCM so they don't appear?
Re: Removing EVAP, any computer tuners here?
Posted: Mon May 02, 2016 9:55 am
by circuitsmith
What do you expect to gain by doing this? Trying to avoid fixing a broken EVAP system?
Besides more pollution you'll decrease your MPGs slightly; and your gas will evaporate and go stale faster if you don't allow the tank to build slight pressure.
Posted: Tue May 03, 2016 7:47 am
by samsonite
circuitsmith wrote:What do you expect to gain by doing this? Trying to avoid fixing a broken EVAP system?
Yeah, fix the problem by removing it.
I guess i could fix it... Where to start? No check engine light/ no codes. Should I replace the charcoal canister/box? Check the pressure valve?
Posted: Tue May 03, 2016 9:51 am
by circuitsmith
samsonite wrote:Where to start? No check engine light/ no codes.
So what's the problem? Symptoms?
Posted: Tue May 03, 2016 11:01 am
by samsonite
circuitsmith wrote:samsonite wrote:Where to start? No check engine light/ no codes.
Gas pump clicks off constantly. It's really hard to fill. It clicks off nearly 40 times before i get to the full mark. Just bought this Vibe with 63,000 miles
Posted: Tue May 03, 2016 6:46 pm
by Chiadog
Have you inspected the systems components? I'm guessing it won't be this easy to diagnose! But should be an easy diagnosis for a mechanic who regularly works on Corolla's.
viewtopic.php?f=12&t=45202#p512518
Posted: Wed May 04, 2016 7:16 am
by samsonite
Chiadog wrote:Have you inspected the systems components? I'm guessing it won't be this easy to diagnose! But should be an easy diagnosis for a mechanic who regularly works on Corolla's.
HAHA! I'll take a look at it maybe this weekend.
Posted: Wed May 04, 2016 8:21 am
by lannvouivre
You can't alter the PCM. You'd have to get a stand alone system for a mere $1300, and then tuning is $400-800 usually. A piggyback wouldn't touch the EVAP system, and I'm not sure a stand-alone would, either, not without massive amounts of modification.
Posted: Wed May 04, 2016 6:18 pm
by Chiadog
I found this simple test for a plugged charcoal canister on YouTube! You may be able to do this without removing the canister. I'm sure there are other "youtubes" concerning diagnosis of EVAP symptoms.
https://www.youtube.com/watch?v=0hdY29nkXiw
