SCCA Autocross El Toro 3-19-16 & 3-20-16
Posted: Mon Mar 21, 2016 9:49 pm
by B14CK_H4WK
Re: SCCA Autocross El Toro 3-19-16 & 3-20-16
Posted: Wed Mar 23, 2016 5:51 pm
by Derf
Nice, video says you made a few minor adjustments. Everything work out the way you wanted?
Great use for an abandoned airport.
Posted: Mon Apr 04, 2016 10:28 pm
by B14CK_H4WK
Yes the car really really handles 100% better by just putting the caster all the way back on the camber plates which also added some negative camber. I finally felt like the adjustable suspension came in handy, since i was able to change camber within 10 minutes while at autocross. The front wheels sit about -3 camber, 0 toe and the rear is about -1.5 camber. The car literally drove itself after that and felt alot tamer to drive. I was able to drop the PSI a little bit in the front wheels and they also didnt heat up as much in the front after adding the camber. After having this setup now for about a month i can say my tires are finally wearing out evenly lol. The car is always in corners and loves it.
