				Adding Cruise in 2009 Base Model
				Posted: Tue Dec 29, 2015 6:53 am
				by pilarskica
				I'm looking at a Vibe with no cruise.  I was doing some research and I saw that you can get just the stalk and install it while other ones say you'll need the harness also.
Anyone know for sure?
Thanks
				Re: Adding Cruise in 2009 Base Model
				Posted: Tue Dec 29, 2015 9:25 pm
				by trb
				Should just need the stalk.  I know that is all you need for the 05-08 base models since I got one for another member on here.  I actually think it is the same switch for all year models.
Edit:  I just looked a bit and looks like the 09-10 is different.  Found this thread:
viewtopic.php?t=30424
				Posted: Thu Feb 11, 2016 1:11 pm
				by pilarskica
				I was able to successfully add cruise to my 2009 base Pontiac vibe.
The stalk I got was this one
http://www.ebay.com/itm/191620284578.
Toyota Camry Corolla Matrix Prius Yaris Cruise Control Combo Switch 84632-08021
Just make sure you get the wire that goes along with it too.
All i had to do was disconnect the battery, take out the airbag and plastic insert and then move the horn wire from the old harness to the new one.  There is a trap door on the clip that lets you release the wire.
For installation I used 1" #10 screws from home depot.  Put everything back together and took the car for a spin.  Cruise worked perfectly and all for under $30.
