Engine above 3000 shuting on/off
Posted: Wed Aug 20, 2003 12:48 pm
by Pawel
Hi all. I got a quick question. Does anyone know what might be wrong if engine above 3000 rpm acts like "there is a fuel shut off"? From 0 to 3000 rpm everything is ok, then as soon as rpm needle goes beyond 3000 rpm it shuts on and off (similar when fuel shut off engages to prevent over reving the engine).
Re: Engine above 3000 shuting on/off (Pawel)
Posted: Wed Aug 20, 2003 1:10 pm
by AKLGT
when is this happening? there is a rev limiter on the vibe if the engine is not warm enough. this was discussed in a previous thread about a month ago. if it's when you first turn the car on before the engine warms, then it's the limiter. if not, then ..... you may have a prob.
Re: Engine above 3000 shuting on/off (trdvibe)
Posted: Wed Aug 20, 2003 8:40 pm
by Sub-Vibe-R
At only 3000 rpm!!! It looks like your car have a problem. Even if mine is cold, I can rev. my base up to 6400 rpm before getting the cut off.
Re: Engine above 3000 shuting on/off (Sub-Vibe-R)
Posted: Wed Aug 20, 2003 9:09 pm
by slbpsi63
The 3000 rev limiter is only on the 2ZZ engine. I test drove a celica and that damn rev limiter kicked in for the first 5-10 minutes. Anything longer than that I would get my engine checked out.
Re: Engine above 3000 shuting on/off (slbpsi63)
Posted: Wed Aug 20, 2003 9:47 pm
by goodvibe
There is no 3000rpm rev limiter though this motor will do things like that to protect itself. It won't hit lift when cold. 6000rpm. Check your MAF sensor. It may be oiled from your CAI filter creating an overly lean mixture and triggering the knock sensor or other failsafe. Clean it and reset the ecu. It may be something else but it's a quick and easy first check for a common issue.
Re: Engine above 3000 shuting on/off (goodvibe)
Posted: Wed Aug 20, 2003 10:37 pm
by Pawel
quote:There is no 3000rpm rev limiter though this motor will do things like that to protect itself. It won't hit lift when cold. 6000rpm. Check your MAF sensor. It may be oiled from your CAI filter creating an overly lean mixture and triggering the knock sensor or other failsafe. Clean it and reset the ecu. It may be something else but it's a quick and easy first check for a common issue.what would be the best way to clean it? what should I use to do it?And the engine behaves liek that when at normal operating temp.
Posted: Thu Aug 21, 2003 12:22 am
by Pawel
by the way, where are the ECU fuses? and, where are fuel pump fuse or relay?
Posted: Thu Aug 21, 2003 12:34 am
by robdog
Problem there. See dealer for details.....
Posted: Thu Aug 21, 2003 11:09 am
by goodvibe
2 in the fuse box labeled EFI. One is correct but pull them both or just disconnect the battery.
