Vibe Transmission issue?
Posted: Wed Jul 01, 2015 5:09 pm
Wife calls me today. The Vibe won't go into Reverse or Park. I get home, take the console apart and disconnect the shift cable. The shifter moves well without the cable attached. I open the hood and try to shift the trans into reverse or park manually at the shift arm of the trans. No luck past Neutral. I can hear a clunking sound when I shift it quickly via manual process. Anyone had this before on a 2003 Vibe, Automatic trans?? It is not a fluid issue. I regularly have the fluid and filter changed at a mechanic shop I trust. I supply the fluid and filter to him to make sure it is correct. The trans has about 240K on it but runs like a top and shifts well in all forward gears. It is NOT a slipping condition. I've had three Vibe's so far so I do have some understanding of what constitutes the condition mentioned and how to check this. I need someone who knows what else may be causing the trans not to shift into reverse or park, even manually.
Thank you!
Thank you!
