Fan only the highest speed works
Posted: Wed Jul 01, 2015 12:07 pm
by Mitch
All of a sudden I can only get fan to work when I put it to the highest speed (with A/C on, the same).
It's a Pontiac Vibe 2006.
Any ideas what has to be fixed/replaced are greatly appreciated!
Re: Fan only the highest speed works
Posted: Wed Jul 01, 2015 1:35 pm
by gtv237
Blower motor resistor.
Posted: Wed Jul 01, 2015 3:05 pm
by SeattleJeremy
gtv237 wrote:Blower motor resistor.
Yep, it's a really common issue, and it's an easy thing to fix.
Pop out the glovebox, reveals the blower motor, the resistor is located on the outside of that box. You'll find it quickly.
Posted: Thu Jul 02, 2015 7:00 pm
by Mitch
Thanks guys, you are awesome!
Ordered the part!
Posted: Tue Aug 04, 2015 12:08 pm
by pauleouellette
Fan not working in any position. Moved passenger seat back to rear position and bumped stop and fan started working again in all positions. What?????????
Posted: Tue Aug 04, 2015 4:20 pm
by gtv237
pauleouellette wrote:Fan not working in any position. Moved passenger seat back to rear position and bumped stop and fan started working again in all positions. What?????????
The fans DC motor has flat spots on its windings. The bump knocked it past the flat spot. You need to replace the blower motor.
