Fan only the highest speed works
Mitch
Post by Mitch »
All of a sudden I can only get fan to work when I put it to the highest speed (with A/C on, the same).
It's a Pontiac Vibe 2006.
Any ideas what has to be fixed/replaced are greatly appreciated!
gtv237
Re: Fan only the highest speed works
Post by gtv237 »
Blower motor resistor.
SeattleJeremy
Post by SeattleJeremy »
gtv237 wrote:Blower motor resistor.
Yep, it's a really common issue, and it's an easy thing to fix.
Pop out the glovebox, reveals the blower motor, the resistor is located on the outside of that box. You'll find it quickly.
Mitch
Post by Mitch »
Thanks guys, you are awesome!
Ordered the part!
pauleouellette
Post by pauleouellette »
Fan not working in any position. Moved passenger seat back to rear position and bumped stop and fan started working again in all positions. What?????????
gtv237
Post by gtv237 »
pauleouellette wrote:Fan not working in any position. Moved passenger seat back to rear position and bumped stop and fan started working again in all positions. What?????????
The fans DC motor has flat spots on its windings. The bump knocked it past the flat spot. You need to replace the blower motor.
