04 exhaust manifold heat shield bolts
Posted: Tue Apr 28, 2015 2:25 pm
by decarabas
Ok so I find myself again at odds
04 base model. I removed the exhaust manigfold heat shield as the 2 bottom bolts had rusted through the shield and it was rattling somthing fierce. 2 top bolts came out fine but the bottom bolts seem round with a very shallow and not the right shape to put a socket on it. There was some wirey mesh around the bolts that I removed and assumed was some sort of buffer material. So I guess my question is how do you get the bottom bolts out?
Thanks in advance.
Re: 04 exhaust manifold heat shield bolts
Posted: Wed Apr 29, 2015 1:35 pm
by TraumaForYou
I had the same problem with mine man. My heat shield rusted around a bolt and it rattled like a babies rattle!! :o I used a rivet gun to attach it back on and it worked beautifully!!! You should give that a try. Rivet gun + heat shield = success :D
Re: 03-08 Exhaust manifold heat shield bolts missing
Posted: Sun Apr 24, 2016 10:59 am
by Derf
Had similar issue on '05. Appears it may be a common problem in the rust belt. Did not have any rivets big enough, ended up using a hose clamp to keep the heat shield in place. Used arge hose clamp to secure shield (102-152mm Stainless clamp worked fine). Plugging open bolt holes with exhaust repair compound, used Permatex MTK-1 Item 80335 (used before on several other projects holds up well).
Missing bolts, open holes in exhaust manifold letting gasses out
Hose clamp in place and holes plugged.
Posted: Sun Apr 24, 2016 11:05 am
by lannvouivre
Leaking exhaust gases!? Looks like I need to get mine out of storage and inspect it; didn't notice anything like that...
