Tuneage?
Posted: Sun Oct 05, 2014 7:38 am
by dnoishere
...so maybe I'd like to get a new radio for a 2007 vibe with the monsoon system...any tips or ideas on what I can get and where I can get it from? Don't want to spend too much though. Thanks.
Re: Tuneage?
Posted: Sun Oct 05, 2014 10:33 am
by dnoishere
...thinking about this one:
http://www.crutchfield.com/p_130X520UI/ ... ml?tp=5684" onclick="window.open(this.href);return false;
but where does this go?
http://www.crutchfield.com/p_142SLC4/Sc ... erter.html" onclick="window.open(this.href);return false;
Re: Tuneage?
Posted: Sun Oct 05, 2014 2:03 pm
by Raven
I put this one
http://www.crutchfield.com/p_105KWR910B ... ml?tp=5684 in my daughters '06 about 2 months ago. She loves it. Has bluetooth etc. bla bla bla.
Re: Tuneage?
Posted: Sun Oct 05, 2014 2:23 pm
by dnoishere
did you use the Line Output Converter? how does it hook up?
Re: Tuneage?
Posted: Sun Oct 05, 2014 2:41 pm
by ColonelPanic
I've been thinking about taking the '03 into the modern era with that unit as well. Seems to do a lot of stuff for very little coin. Barring how difficult it is to use, so we need to find a place locally where we can demo it. Neither of us want anything overly complicated. Looking through the manual it doesn't seem too bad.
Got any pics of that one installed?
Re: Tuneage?
Posted: Sun Oct 05, 2014 2:47 pm
by Raven
dnoishere wrote:did you use the Line Output Converter? how does it hook up?
None required. Is it necessary with the Monsoon system?
Re: Tuneage?
by ColonelPanic
Take all 8 wires from your head unit's speaker outputs into the input side of this thing and the 8 wires on the harness for the speakers are connected to the output side.
You don't *have* to have one if you have moon & tunes -- I didn't at first when I had my '03 years ago, but it sounds not great. You're sending a high powered signal into an amplifier for amplification so it adds a lot of white noise. This lets you attenuate the signal coming from the head unit, it sounds much better with one of these installed.
Re: Tuneage?
Posted: Sun Oct 05, 2014 2:49 pm
by Raven
I don't have pics. It seemed quite simple to use even with "older" failing eyes. Basic functions have large easy to see and use buttons.
Re: Tuneage?
Posted: Sun Oct 05, 2014 4:13 pm
by dnoishere
Raven wrote:dnoishere wrote:did you use the Line Output Converter? how does it hook up?
...well crutchfield says I need one...?
Re: Tuneage?
Posted: Sat Feb 21, 2015 5:42 pm
by dnoishere
...well I got my new JVC-KW-R910BT installed...sounds pretty good. Thanks Raven for the suggestion...now should I get me some speakers? I have a 2007 with the Monsoon package...what size speakers did the factory put in?
Re: Tuneage?
Posted: Sat Feb 21, 2015 6:07 pm
by Salsa Guy
6.5" I believe and you'll need some adapters also ($10)
Re: Tuneage?
Posted: Tue Feb 24, 2015 8:19 am
by runningslow
dnoishere wrote:...well I got my new JVC-KW-R910BT installed...sounds pretty good. Thanks Raven for the suggestion...
Same radio I just installed in mine. Question, what dash kit did you use? The one I bought (honestly forgot the brand, but it wasn't Scosche or Metra), the bezel filler panel doesn't fit over the face of the radio, so I've got a nice gap all around the radio.
Re: Tuneage?
Posted: Tue Feb 24, 2015 4:37 pm
by ColonelPanic
runningslow wrote:dnoishere wrote:...well I got my new JVC-KW-R910BT installed...sounds pretty good. Thanks Raven for the suggestion...
And another Viber with the same JVC.
I finally decided to pick one up a couple months ago.
My kit as the
American International kit that was free from Crutchfield. I almost ordered a different one to have a backup just in case I didn't like it but this one seems to fit fine and it's sturdy enough. Not much of a gap surrounding the radio on mine. I'll get a closer pic tomorrow.
Good choice in head unit, lots of bang for the buck.
Re: Tuneage?
Posted: Wed Feb 25, 2015 12:29 pm
by runningslow
Yep. I love it. Its perfect for my needs. I also love the fact that I was able to very closely match the display to match the red look of the dash lights at night.
I'm just going to have to get a new dash kit. This is what I bought and the only parts I was able to use from it were the brackets:
http://www.ebay.com/itm/111019998376
Re: Tuneage?
Posted: Wed Feb 25, 2015 2:22 pm
by dnoishere
....some how ColonelPanic got in my car and took a picture of my new head unit...
That looks like the dash kit I got and installed runningslow...I had to cut off most of the tabs though...
Re: Tuneage?
Posted: Sat Mar 07, 2015 10:08 am
by dnoishere
So here's my new unit installed....pretty easy to install...notched out the bracket for my USB cord and dropped it down into the middle lower storage box..all nice and concealed.
Re: Tuneage?
Posted: Sun Mar 08, 2015 1:37 pm
by ColonelPanic
That's a clever workaround for the USB cable!
Re: Tuneage?
Posted: Sun Mar 15, 2015 8:50 am
by dnoishere
....found a use for some leftover flooring underlayment...and whats this white box for inside the door?
