Speed gauge wire for nav system
Posted: Sun Sep 07, 2014 11:10 am
by kumquat
I'm installing a JVC KW-NT300 navigation system. Looks like I can bypass the parking brake by just grounding the appropriate wire, which is great. But I need to hook it up to a speed sensor wire as well.
What wire should I use for this?
Re: Speed gauge wire for nav system
Posted: Tue Sep 09, 2014 5:29 am
by kumquat
The service manual lists pin 35 and 36 on the instrument panel connector both as "vehicle speed sensor signal." One is VT (violet?) and the other is "L-GN" (light green?)
Which should I use?
Posted: Sun Sep 14, 2014 4:53 pm
by kumquat
For anyone else curious, I used the violet wire and it's working fine.
