Hatch opening rubber gasket
Posted: Sun May 04, 2014 6:06 pm
by jake75
I was unloading bags of mulch and evidently dragged some over the bottom part of the hatch molding - pulled it out - is loose now. Is this a do it yourself job to fix - Do I need an adhesive? I tried to push it back but it isn't the same. Keeps coming out again.
Re: Hatch opening rubber gasket
Posted: Sun May 04, 2014 6:40 pm
by KITT222
It just gets pushed into place, but you need to make sure it is on the car's pinch, and the gasket's groove is the thing it's going over. I've done this to my own car a few times when pulling parts off. Try checking the other areas of the gasket to make sure it is all in there properly, as it may not be completely pressed on, and may be bunching up. If it ended up stretched you may need a replacement, or look up a way to shrink it (if possible).
Posted: Sun May 04, 2014 8:30 pm
by kostby
Decades ago (1994, while replacing the door/window gaskets for my 1984 Rabbit Convertible) I used '3M weatherstrip adhesive' to keep everything in place:
http://shop.advanceautoparts.com/p/3m-s ... /7160143-P" onclick="window.open(this.href);return false;
As I recall, this stuff was MUCH cheaper 20 years ago, but then what wasn't?
DISCLAIMERS: Bright yellow, so any extraneous drips will show, and smells horrible while drying, so use with plenty of ventilation. The solvent in it likely melts some plastics, like the Vibe gray cargo-hold plastics, so apply with care!
It is apparently also available in Black now:
http://shop.advanceautoparts.com/p/3m-s ... /7720004-P" onclick="window.open(this.href);return false;
I'd probably try either of these before the DollarTree 2 Tubes for $1 Superglue Gel, because the 3M stuff can flex and bend, while Superglue Gel would not.
Posted: Sat Jul 12, 2014 7:07 pm
by jake75
KITT222 wrote:It just gets pushed into place, but you need to make sure it is on the car's pinch, and the gasket's groove is the thing it's going over. I've done this to my own car a few times when pulling parts off. Try checking the other areas of the gasket to make sure it is all in there properly, as it may not be completely pressed on, and may be bunching up. If it ended up stretched you may need a replacement, or look up a way to shrink it (if possible).
I must not have been pushing/aligning correctly - seems my daughter in law has succeeded in getting that gasket back into place - and stay there - without using any any adhesive.
That probably would have been charged at least 1 hr mechanic time at the dealer.
Posted: Sun Jul 13, 2014 4:19 pm
by Caretaker
given all the recall work GM will be doing for the next year, your car would probably have been held hostage at the dealer all day just for that job. "We'll give you a call when we get it done." Yeah, sure you will.
I'm glad you got it fixed in the driveway Jake.
Posted: Sun Jul 13, 2014 8:38 pm
by jake75
My dealer where I got my 2009 - former Pontiac/GMC, now Chevrolet, is pretty good. I would have bought my 2003 Vibe there but they didn't have anything without a moon roof at the time. My daughter in law was the one who knew how to get the gasket back in place - not me. I assumed it had to be glued to stay in place. Evidently not so. She is a gem.
