newb! ; What spark plugs do you suggest for 2007 Vibe auto?
Posted: Thu Apr 03, 2014 10:13 am
by pointbob
newb! ; What spark plugs do you all suggest for 2007 Vibe auto (base model)?
THANKS!
Re: newb! ; What spark plugs do you suggest for 2007 Vibe au
Posted: Thu Apr 03, 2014 10:29 am
by Doug14
NGK iridium or NGK laser iridium(i have these)
Posted: Thu Apr 03, 2014 11:59 am
by pointbob
Doug14 wrote:NGK iridium or NGK laser iridium(i have these)
Would these work?? there so many...is 4589 IFR6T11 correct?
http://www.ebay.com/itm/8-PCS-NGK-Iridi ... 2a&vxp=mtr" onclick="window.open(this.href);return false;
Posted: Fri Apr 04, 2014 5:14 am
by Doug14
According to the NGK website part numbers, those particular plugs appear to be for the 2ZZ-GE engine (vibe gt) you will need the 1ZZ-FE plugs which are part # IFR5T-11 and stock # 4996 for the laser iriduim plugs or part # BKR5EIX-11 stock # 5464 for the iridium IX plugs. Hope this helps!
Posted: Fri Apr 04, 2014 6:48 pm
by Mark
No. Use this one: http://shop.advanceautoparts.com/p/ngk- ... spark+plug.
Advance has a $10 rebate when you buy 4 right now.
