Factory radio bad reception on 06'?
Posted: Fri Jul 05, 2013 9:23 am
by Nyx8
I have a 2006 base Pontiac Vibe and I've been noticing the radio (monsoon system) has been crappier with reception than when I first got it like 2 years ago. Anyone know if it's a problem with the radio or antenna?
Re: Factory radio bad reception on 06'?
Posted: Tue Aug 13, 2013 4:58 pm
by Nyx8
Bumpin' it up!
Posted: Thu Oct 31, 2013 11:16 am
by M1MECHANIC
It could be the amlifier for the antenna. its located in the base of the mast. If that goes out or is going out you get bad reception as a result. Also you do have the factory antenna on it still right? That can also cause bad reception as the system is set for that spacific ohm rating inthe mast.
