				speed limiter
				Posted: Tue Jun 04, 2013 4:33 am
				by passtimik
				has anyone had experience disabling their speed limiter? any results, good or bad? i'm not condoning speeding, but topping out at 90 was a little weak for my taste.
				Re: speed limiter
				Posted: Tue Jun 04, 2013 5:13 pm
				by vibenvy
				Unless you race a vehicle on the track, I don't see any reason why a daily driven vehicle needs to go any faster than 100 MPH. Just my $0.02.
				Re: speed limiter
				Posted: Tue Jun 04, 2013 10:15 pm
				by star_deceiver
				The limiter's there for a reason, usually because of the speed rating of the tires or so you don't destroy an overstressed part at speed.  I recall that Vibes speed limiters are set around 110mph for base models.
				Re: speed limiter
				Posted: Wed Jun 05, 2013 3:59 am
				by beemerphile1
				I honestly didn't know there was a speed limiter.    It is highly unlikely I would ever discover it for myself.  Can't help you on modifying the device.
I won't make any judgements on your desire to remove the limiter but, please keep your high speed work on the track and not the streets we share.
				Re: speed limiter
				Posted: Mon Jun 10, 2013 3:14 am
				by passtimik
				I appreciate all of the "father - son" comments, but back to the original question.
Has anyone disabled their speed limiter? Any comments on that question would be appreciated.
				Re: speed limiter
				Posted: Mon Jun 10, 2013 7:21 pm
				by mac99d
				Yes I have but I have a piggy back ECU with an option to do that...If you want to do it to your can you will need to trick the ECU in to thinking that it is not going faster than it really is. Maybe some kind of voltage cut on the speed sensor wire might do it. Basically as the voltage rises it never reaches the point to shut the car down. I am however in no way an expert in electronics I just like to tinker with everything. Maybe someone with more knowledge in diodes and resisters might chime in.
				Re: speed limiter
				Posted: Fri Jun 14, 2013 6:24 pm
				by passtimik
				Thank you
				Re: speed limiter
				Posted: Mon Jun 17, 2013 7:52 pm
				by star_deceiver
				You could also try running secondary power to the fuel pump as power is cut to it when the speed limiter is tripped.  (no fuel - no more speed)
